Is DSP useful?
  • #61
    ADC
    • #62
      @JC1 - "...FPGAs can outperform DSPs, says study...."
      see https://www.geotech1.com/thuntings/s...highlight=FPGA
      post 9
      • #63
        Originally posted by TheWizard View Post
        upper picture
        Not ADC,
        Sample must very very fast for low error....
        • #64
          If no-one here has used the MikroElektronica stuff, then what are they using?
          How about you Wizard? I see you're using UEStudio http://www.ultraedit.com/index.php?n...owpage&pid=150
          but what about the programmer/debugger?
          I'm thinking about buying the MikroElektronica EasyStart PIC kit, and would like to get some feedback from any users. Good or bad?
          I currently use the PicMicro development board from Matrix (click here), I have both Rev 2 & Rev 3. I have been intending to buy an EasyPic4 board for some time, maybe soon.
          - Carl
          • #65
            The study compares some pretty high-end chips ($200-plus) with pretty high-end power (1-watt-plus) that aren't the least bit suitable for a battery-operated detector. Both DSP and FPGA start out at sub-$10, and you should always buy only what you need, especially keeping an eye on power. It's very possible that a lowly Microchip DSPic is plenty good enough, depending on what you want to do.
            In a current PI design, I am using a PIC chip with a 10-bit ADC (good enough), throttled back to 1MHz (good enough), and pulling only 300uA. My battery will last a very long time.
            - Carl
            • #66
              - Carl
              So what type of Digital Signal Processing are you
              doing to the signal with this setup?
              Carl.
              • #67
                DSP not suitable
                - Carl
                Now if this type of processing IS require
                do to any REAL digital signal processing
                then you are right.
                DSP IS NOT SUITABLE FOR METAL DETECTORS.
                Still Garrett pulled if off for real.
                Now if the discussion is about what kinda of
                processing a little 1 MHz pic is going to do,
                don't kid me or yourself.
                Tell me what you are doing.
                I ain't buying the story.
                About any real deal.
                • #68
                  Exponential Moving Average,
                  Integrator //y[n] = a * y[n-1] + x[n]
                  Create Audio Tone.....
                  • #69
                    DSP Part....
                    • #70
                      Running average
                      Hi Wizard,
                      Yea this is the typical stuff done
                      by all the detector manufacturers
                      with their microprocessors which
                      is NOT Digital Signal Processing
                      which some my wish to act like it is.
                      1. Get some Engineering books that say
                      Digital Signal Processing on the side of
                      the book and look inside. That IS DSP.
                      2. If you don't believe that, then understand
                      that the little slow toy microprocessors
                      ARE NOT going to yield "state of the art"
                      design. They NOT going to do all the sharp
                      filters and noise reductions techniques or any
                      thing but run an average {easier done with
                      leaky integrator} and light some lights and display.
                      Now I have NO doubt NO real DSP will be done
                      by the Collective design team. We will be lucky
                      if everybody/anybody even understands what this
                      really is.
                      Not someone's made up pointless la la land definition.
                      • #71
                        Hi JC1
                        What for you is "Digital Signal Processing"
                        FFT, DCT.... ?
                        I not need FFT like Garret for Pulse Induction.....
                        "A digital signal processor (DSP) is a specialized microprocessor designed specifically for digital signal processing, generally in real-time computing."
                        http://en.wikipedia.org/wiki/Digital_signal_processor
                        http://en.wikipedia.org/wiki/Digital_signal_processing
                        http://en.wikipedia.org/wiki/Filter_...igital_filters
                        • #72
                          - Carl
                          Are you happy with the features on the PicMicro board, and do you have any comments concerning the MikroElektronica offering?
                          • #73
                            DSP Classroom
                            Hi JC1
                            FFT, DCT.... ?
                            Hi Wizard,
                            Just what it says:
                            NOT a general purpose slow toy designed specifically
                            for lighting lights.
                            Wizard don't take me wrong, remember this is still
                            left over from the Design Dream Team stuff,
                            where Sean Goddard who at least does understand
                            what is meant by any Serious DSP was proposing a
                            DSP programmer and a laptop computer. That didn't
                            seem to be a problem, though 1 Watt now does, even
                            though Minelab PIs use more that 1 WATT. sure you
                            have to carry a GEL Cell battery around, but heh
                            you know what????? Guys WILL carry that battery
                            around if the detector works well.
                            But the real deal is I didn't buy into some kinda of
                            DSP wet dream. And I said something about it.
                            And I'm still waiting from the beginningg o0f this
                            story, for anyone to tell me WHAT they in their dreams
                            are going implement in DSP. And then I am going
                            to tell them just how hard or easy that really is to do.
                            Now I am not in any way putting down what you
                            have done. I think that is great !!!! because there
                            are many who actually do very little. And a moving or
                            running average is very typical with a general purpose
                            microprocessor to do. But it is not BRAND NEW STATE OF
                            THE ART, which is about the only specification that the
                            new great sell and get rich detector has at the moment.
                            It was not to be constrained in design, but already the
                            processing must not be capable, but the first design
                            requirement is that it be cheap and low power.
                            So now it will be easy to show that the new great state of
                            art detector will be nothing.
                            • #74
                              JC1, you very underrate us...
                              Ok I understand you, Now the MCUs is very fast and DSP core is not need,
                              but Integrator like y[n] = a * y[n-1] + x[n] is the basic of Digital Signal Processing....... never mind....
                              In my old PI design I use not analog integrator, How I make this...?
                              How I make noise reduction, detection, tone creation....
                              I make many test and source is optimized to normal C algorithm(I have free MCU time for this and use not DSP core, but if I need....
                              Yes, Power Supply... fast MCU - current is 200 mA, I think and about this...
                              MineLab - GP3500 - 2,400kg, 12Ahr - 10h work...
                              JC1, I make this research more 10 years... Now technology is ready for this...
                              If Minelab, Garret can not do this - some other CAN or will try.....
                              • #75
                                Garrett did do this. With a REAL DSP CHIP,
                                Analog Devices DSP part number is in Patent.
                                Think it is 40 MHz part. But to be doing DSP
                                you are going to have to do more than integrate
                                the ANALOG OUTPUT. That is my point.
                                Plus to have new "state of the art" DSP
                                detector you will have to do everything
                                in software, the front end will only be an
                                amplifier. Nothing more.
                                And I'm glad Carl's new low power detector
                                only uses 300 uA of current. Which seems
                                like the Xmit power is a bit on the low side for
                                this to be a very exciting detector.
                                But no this is going to turn in a big ego thing
                                real quick, I know what level of effort is required.
                                But we will see many years from now if anything
                                comes from this endevor.
