Fantastic P.I front end building block
  • #46
    Originally posted by JC1 View Post
    High Sharky,
    Yes to both of those, but also that the double correlated
    sampling moves these external noise sources around in
    frequency. particularly the movement into lower frequecies
    like HZ and subHz.
    Maxim.
    Undersampling is a powerful tool that can be used effectively in selectedapplications. It allows an ADC to behave like a mixer in that it can takea modulated high-frequency carrier signal and create an image that islower in frequency . In this way it behaves like a downconverter.
    One drawback of undersampling is that unwanted signals can appear in the desired band of interest and you cannot differentiate them from the desired signal.
    http://www.maxim-ic.com/appnotes.cfm/an_pk/928
    Here comes DSP chips , use fft,dft filtering . One nice approcah is not to use charge pumps,instead use 2 separate batteries, use optoisolators where ever necessary, keep a good low noise linear analog front end (dont use high feed back resistors), this should be in linear region, then follows adc then folows dsp chip.
    • #47
      moving
      Hi Sharky,
      My point is one of not being able to hit a moving target.
      The internal/external noise will be in effect modulated by
      the double correlated samping and will be all over the
      passband of the detector. Filter all you want, analog or
      digital, if you do you are filtering the signal of interest
      at the same time. No dsp magic is going to make some
      facts go away. Nor will DSP wishful thinking.
      Thats my point. Now if someone has what they feel is
      productive DSP approach then post it up and we can
      debate the merits. This isn't happening and isn't going
      to happen because either it is a "big million dollar secret"
      or they got nothing.
      I bet the later.
