Question about magnetism
  • Question about magnetism
    If a piece of iron stays in the ground for a long period of time does it get magnetized by the earth's magnetic field.
    Weak...very weak. Alternative field produced in coil will cancel it easy.
    I know what are you pointing at!
    If that iron item has some "radiating" preference, than we wouldnt need TX at detectors, only RX, to "sniff" arround for simillar metals...this could be pretty tricky, beware, you might become LRL'st!!!
    Magnetometer is better solution than.
      Sweet! So ivconic, you're saying all we need is a very sensitive LRL, and we can detect? Sounds good to me!
      (Don't worry. I've not gone to the dark side, I'm just joking )
          ivconic,it is the function metod of magnetometers work,reading the intesity of the magnetic fields...is the future of hunting and researshing...
