LM318 Voltage
  • LM318 Voltage
    Hi all,
    I read the LM318 data sheet and found that it operates from supplies of +-5V to +-20V.
    I am currently using one in my PI with +-4V supply rails. It works OK.(sensitivity is excellent)
    Does it matter anything ?
    Best regards,
    1843
    Ηι 1843.
    If it works OK then no problem. At 4V maybe some characteristics to not be the same as at the table of datasheet.
    But if it work perfect ?????????
      Carl bad voltage
      Originally posted by 1843 View Post
      Hi all,
      Best regards,
      1843
      The internal bias for the transistors will be improper if its less than 5V, lets ask carl publicly in this forum,
      The LM318 input bias /cutin voltage is 0.7 for ant bipolar base inputs, if we apply 10microvolt signal where is the bias coming from, the layout of internal schematic of LM318 doesnt show any biasing. Lets ask this to carl tyoo
        Hi Geo,
        I will operate it by +-5V to see that the sensitivity becomes more or not.
        Best regards,
        1843
          Hi 1843.
          Let me know
            Hi Geo,
            I tried it... sensitivity was the same... I also tried other opAmps like LF357 with +-3.5V, they all worked without any problem.
            Best regards,
            1843
