Two box detector VVLF??
  • Two box detector VVLF??
    Since it's darn cold outside I've been thinking of building a very very low frequency two box detector. Has any one tried to operate at or about 1KHZ? Thinking it should be good for median to large objects at greater depths and not bothered by smaller items near the surface. Input welcome. Charles
    If you will search at forum, there is the T/R Locator from Sevzirfo.
    It work at 2Khz.
    Very good 2Box detector
      hi sekiar gary chemelec curently plan a t/r locator 2khz tow box detector.
        2 box modification
        Dear Charles (if u r real Charles)
        As per one manufacturer in India, 2box TxRx works fine with a ferrite rod both at RX and TX front ends....just a wire loop of 10's of turns (may be 40) is not sufficient.
          hello charles you opinion please, what? is best coil for two box , round of square? what diameter mesure is major
          thanks
          best regards
          detectoman
            Round or square?
            I've seen both, however most have not been round. As far as size I guess it has a lot to do with tx/rx seperation, tx power and receiver gain and the ability to balance the two loops. I have wondered just what a system with 3 or 4-ft diameter loops seperated by 6 or more ft. would work as far as the depth and the smalles object that it would detect. May be some one has tried and will tell us about it. Charles
              thanks my dear friend charles, this project tipe big detector is fabulous
              i am very happy whit your presence here, say us most of your experiencia on two box
              apologies for my englisk
              you speak spanish?
              other question: how can the two box work whit both separate box
              for the procese search inside the hole
              otra pregunta, cual es la forma de operar con las dos cajas separadas? y como hacerlo
              para detectar las paredes del hoyo, he oido que manera llevando las cajas muy separadas entre dos personas se puede detectar con gran profundidad, hasta 15 metros?
              le mando un abrazo
              best regards
              hobbist detectoman
