ATmega8 Voltage Reference Problem
  • ATmega8 Voltage Reference Problem
    Hi all,
    I tested some ATmega8 today. Their ADC reference is set to 2.56V and the voltage reference is externally decoupled at the AREF pin by a 22uF cap.
    But in actual I saw that ATmega8's read 1023 of ADC value only for 2.63V input voltage and not 2.56V...!?
    I think that they are not original parts... Maybe are produced by a bad factory.
    Any idea?
    Best regards,
    1843
    Hi !
    I have the same problem.
    I am sure that the chip are originals.
    I bought many from different seller.
    I used a cap of 100nF connected to AREF for decoupling.
    I saw that without cap the voltage is different.
    I solved the problem using an external 2.048V voltage reference.
    Best regards,
    Maverick ITA
      Did you actually measure the AREF pin?
        Hi 1843,
        The following was cut and pasted from page 248 in the ATMEGA8 documentation.
        V
        INT Internal Voltage Reference 2.3 2.56 2.7 V
        About 17.39% tolerance.
        bugwhiskers
          No, I measured the ADC input signal.
            Originally posted by bugwhiskers View Post
            Hi 1843,
            V
            bugwhiskers
            Yes you are right! I didn't read that!!
              So if you measure the AREF pin, you will likely find it is very close to 2.63V. If you want a precision full scale range, then you should be able to provide an external precision reference voltage from, say, a factory-trimmed bandgap chip. Or from a pot adjustment.
