Hi Carl,
The term "saturation" was about the best term I could think of to use to try to explain that increasing the coil current on time past the target TC has little effect on the target response that can be seen or used. I am not sure what else to use in less then highly technical terms to say the same thing. So, saturation seemed to fit.
My interpretation of what happens after the pulse on time has reached the target's final time constant is any additional rise in target current is because of its resistance.
I agree that what would be seen in a target or the result of a target does require the current to be changing. Stop any current increase or decrease and target signals stop. I guess one can think of the target and coil relationship as a loose coupled transformer with the target having a finite load.
You are correct, the coil's actual TC doesn't change, but increasing the pulse on time will lengthen the discharge time since the current has risen up higher on the charge TC curve. So, it isn't changing the actual Time Constant but it is changing the coil's discharge time or maybe stated another way, the effective portion of the TC curve.
In a nutshell, I probably should have written what I did a little differently. Instead of saying "effective coil TC", I probably should have said something like the effective level on the coil discharge TC or simply referred to the fact that higher coil current will increase the coil's discharge or decay time. It is difficult to try to explain just what is happening and keep all information in very basic terms. In this case, I probably could have done better.
As for what happens with small gold signals and the ability to detect this type of target, the coil TC has a major effect. To sample early, which is necessary to detect real small gold, requires the coil decay signal occur as fast as possible. Once a person has reached what they feel is the ideal coil winding technique, then the only way to further reduce this decay time is to simply reduce the coil peak current. This will in turn will reduce the time to decay to 0V (when no target is present) which will allow for early sampling. That is the basic point I was trying to get across.
If one observes the output of the preamp and adjusts the pulse on time with no target present, they will see the decay curve change as the result of the increasing or decreasing of the coil current. This change is small, but when trying to detect very small gold such as a small gold nugget or a small gold chain, it does make a big difference.
This change has an influence on how soon one can sample. Now, introduce a small gold target and the signal from the gold does not change proportionally as the result of the same increase of coil current. As such, the gold signal gets lost, or stated another way, is or can be overwhelmed by the coil decay signal as the result of an increase in coil pulse on current. Again, this is why I used the term saturated, which I thought would better help a person visualize what happens and help a person understand that target signals will not simply take longer to decay in proportion to the coil decay signal. If it did, then it would be much easier to detect small gold.
I hope this help clear up my previous posts. I am also sure later I will see something differently and probably would have stated something differently. Hindsight is great but on the other side of the coin, if self defense is needed, it is simply easier to simply not post anything since I have a tendency to try to not post the absolute, but try to post what I feel might help one better understand or visualize what is happening..
Reg
Reg
