......analogi TIS75.txt
Tesoro Eldorado
Originally posted by ste View Posthello, I'm new to the forum. I'm going to build a tesoro eldorado. I have seen that there are many variations of PCBs, which do you recommend? you have a pattern more up to date? thank you!
The result as depth is the same.
Originally posted by kelt View PostHi ivconic, i almost finish my metal detector tesero eldorado made in you circuit and i ask you what capasitor you put on pin 8 lm308
use 100pf to compensate frequency.
It is necessary only if you use LM308, instead if you use LF353 or TL081 for example then you can remove it.
