Ferrite detector for letter-bomb
  • Ferrite detector for letter-bomb
    Some objects detected by this simple 4 transistor implementation. Can be useful for safe system and other, but needle of syringe is the only small object extremely reluctance for to be detected! E. Foster, you has reason on it!
    Esteban
    Hi Esteban
    is know schematic?
    Thx Michal
      This is simple "hot" wire detector usually used by electricians to locate powerlines in walls, to know where to drill or not, due avoiding electrical shocks. Can be bought in any electrical shop, usually made in China,cheap and unuseable!
        No, no truth, this is more sensitive and is better than many pinpointing type ferrite. A simple idea can give you the very small wire of strapler at inusual distance, try with your Chinese detector if can achieve this distance, for example, or if you can detect the very small silver nugget you can see in the pic with your Chinese detector... Also is very stable and the hand not produce alterations in detection.
        Esteban
