Deepers metal detector
  • Deepers metal detector
    Hi, does anyone know anything about deepers MD.?
    Has i know, this are PI machines and last models has the option to discriminate.
    If anyone, has the schematics of deepers, please share it.
    Here is a link of deepers and a picture
    http://www.metaldetection.net/spanis...ersMF-Espa.htm
    Nelson
    Nelson
    they are from Mexico. Are PIs and not discriminating. What they say means nothing about disc...
    Also I remember a lot of people here blame that "customer service".
    I think these detectors are just old style PIs and nothing more. I haven't schematics but remember well all the threads cause they were HOT! Red hot maybe...
    Anyway... do you need a PI ? Are you sure of that ?
    I mean... if you have hot rocks or bricks around I suggest you spend money just on good VLFs...
    Kind regards,
      HI MAX.
      WELL, NOW EVERYTHING IS CLEAR ABOUT DEEPERS MD.
      NO I DONĀ“T NEED ANOTHER PI MD, I JUST WHANTED TO KNOW IF DEEPERS ARE GOOD MACHINES OR NOT. BUT WITH YOUR HELP I KNOW NOW THAT DELTA PULSE IS STILL THE BEST PI MACHINE WE CAN BUILT.
      MANY THANKS MAX
      REGARDS
      NELSON
      Kind regards,
        Only MDL 8500, nothing else.
        Hi all,
        Friends! don't waste your time for these kind of MDs. there is one kind of MD (MDL 8500) it's really worth, believe me. If you tear 10000 shoes pair to look for all around USA, it's worth.
        I have mentioned and described it a little without any exaggeration or lying here:
        http://thunting.com/geotech/forums/s...2130#post72130
        concentrate your energy to find it.
          Brother of MDL 8500
          Originally posted by michael View Post
          Hi all,
          There is one similar device very similar to MDL,also calibrated in USA,it is the Ground Pioneer 4500,they say it can finf big metal object 8 m deep,its realy true ??? If yes,its not expensive PI...
            Michael, here is the site: http://www.deeptech-bg.com/gp4500.html Does this look any close to what you have? Coils, box, switches, etc.
              Hi, I don't know this device and if works excellently or not. maybe is.
              If I'm right is made in Bulgaria (they mention to Varna and tel code + 35) where I've bad impression of.
              Some things in back panel seems somehow similar to MDL except to RS232, fuse house and speaker. MDL originally had no speaker onlu headphone jack, we ourselves connected a speaker.
              the front panel is entirely different, but these are not reasons for assessment.
              MDL has no discrimination, it’s an all metal detector, but what a detector!!!!!
              GP 4500 seems be like SSP series or Genesis being sold by DTI .
              I've seen many of these kind of PIs, and all had drift in signal intensity when work with.
              Although we own one good discriminator PI that is highly better than Genesis and in power similar to Pulse star II, is nothing in comparison with MDL, after getting MDL we put it aside.
              But one thing there I see is surely different of MDL; how they're using the coils (frame) not similar to MDL.
              as I've mentioned before we hold the coil up to waist and even chest level and easily walk and even run without any problem result is same with hold near ground!!!
              of course the frame should be tough without any swing movement to avoid any noise.
              I don't know can do this with these detectors or not.
              we don't need to use frame with 2 person, one is enough. but use 2 amid handle so one man easily hold the whole frame at waist or even when ground is covered with high bushes at chest level by the time his hands become tired.
              another thing I've told frequently is I'm sure MLD origin is USA. one guy had brought it from USA
              some years ago.
