We are surrounded by the earth's magnetic field. When we look for buried treasure, we can use the earth's magnetic field to give us some indication where to look.
A magnetometer is a passive sensor of the earth's magnetic field. It tells us about distortions of the field.
Such distortions can be caused by iron or steel objects.
A metal detector is an active sensor of magnetic fields.
The coil sends a continuously varying magnetic field into the ground in the case of a VLF detector. Or a pulsed magnetic field for a PI detector.
These time varying fields generate eddy currents in conductors. These conductors can be of the metallic kind, but they can also be in the form of conductive solutions, like seawater that gives a considerable response to the metal detector.
I would like to learn more about the interaction of the various magnetic field that come into action when we expose a target to the magnetic fields from the metal detector.
For example:
The eddy currents in the target generate a magnetic field around the target. This magnetic field is within the earth's magnetic field and causes a distortion in it.
Question:
Is the response that we sense with the coil, the actual magnetic field of the target or is it the distortion that this field causes in the earth's magnetic field?
Question:
What about a target that has it's own magnetic field? Now we have one more magnetic field that interacts.
How do they interact?
Tinkerer
For example:
Question:
Question:
Tinkerer
