BOSCH DMO-10
  • BOSCH DMO-10
    THIS IS CALLED "ALL DIGITAL METAL DETECTOR". IT IS FOR STUD FINDING ?. DOES IT HAVE TARGET ID ??? OR I READ WRONG !! BOSCH HAS A FEW DIFFERENT MODELS BEING SOLD AROUND THE WORLD AND ON E-BAY TOO !! CAN IT BE MODIFIED FOR PIN-POINTING OR MORE ??? ..................EUGENE
    Apparently this detector is able to detect steel, iron and non-ferrous metals. It can also detect the presence of cables.
    So there doesn't appear to be any form of discrimination.
    Other data:
    Depth detection for steel, approx. 50 mm.
    Depth detection for copper, approx. 30 mm.
    Automatic shutdown, approx: 75 sec.
    I don't think this is a stud finder. In my collection I have a Rapitest joist and stud finder, and I can honestly say that's it's next to useless.
    This Bosch unit comes from a quality manufacturer, and it appears to be a proper handheld metal detector. Perhaps you could modify it to take a larger coil and use it for relic hunting.
      BOSCH DMO-10
      HERE IS ANOTHER MODEL . I AM HOPING TO FIND A MODEL WITH ALL THE BELLS AND WHISTLES AND THEN SEE IF IT CAN BE MODIFIED TO WORK WITH A STANDARD SIZE SEARCH COIL !!! DONT LAUGH , THIS WAS DONE IN 2003 , REMEMBER THE P.I PROSCAN PROJECT .THE ORIGINAL DEVICE WAS THE PROSCAN ,WHICH WAS A HAND HELD SCANNER USED AT ENTRANCES TO COURT HOUSES ..ETC... SOME ARE VERY POWERFULL AND WITH SMALL DIAMETER SEARCH-COILS ..................EUGENE
        DMO 10
        Amtech 2005,
        I dont supose you have a manual for the DMO10
          Originally posted by StephenGeorge View Post
          Amtech 2005,
          I have one of these with a manual, what info were you after ?
            DMO 10
            Hi Silverdog,
            I just need the operating instructions.
              Theres not much of it, but I hope this helps
                DMO 10
                Thanks, silverdog,
                that help's me a lot.
