Originally posted by Aziz
it's interesting idea. You can gain xtal stability using uC with external xtal at oscillator pins, easy and effective. Some jitter will be there cause of some uC latency but I think will be at least an order of magnitude more stable than using e.g. NE555/556 like older PI's have done in past... an example is goldscanIV, very powerful device... but now obsolete about these parts, I mean voltage converter, timing and switching device, rest of integrators could be reused or give ideas about design.
Increasing PPS will give you faster response and you'll get easy smaller stuff cause of skin effect combined with eddy currents there... consider that very good PIs by Eric Foster for beach hunting run in the 3KHz range +-200Hz(deepstarII) so using 10KHz will give fair results on small stuff.
I think will be an interesting project.
Kind regards,
Max
