GoldScan IV
  • #46
    gs4
    hi max
    I show is. if (sw1-c)normal switch , that means the (1,2,3) same the point.
    and what is your the meaning
    trimpots
    disc/matrix
    thank for you
    • #47
      Originally posted by jamal View Post
      hi max
      trimpots
      disc/matrix
      thank for you
      no... it's not a normal switch but somethign like in the picture... I said 3-ways... so it's made with 3-separate section that's why s1-a, s1-b, s1-c ... each letter is a section of it.
      So, also if at s1-c is wired the same at different positions the difference there is at other sections , look at schematic carefully.
      Trimpots are small variable resistors placed on pcb , used for tuning of MD.
      disc stays for discrimination; matrix I mean composition of soil... with oxides and everything... can be e.g. clay matrix with oxides etc or e.g. sand-like-matrix like in deserts.
      PS: in pdf you find a little tutorial that explains the use of these switches... if you never did before.
      Kind regards,
      • #48
        hi max
        firstly thank you ...........
        I want go fro,,, you are speak for VLF .
        I have same this detector (VLF443),
        but exist some problems in it and no do .
        important this problems - disconnected in wiring between bc board and switch panel .
        I connected all cables but not doing , I need your help if you have information about it
        note - I draw (BC ) board in my self
        -- attached file type (auto cad)I attempt upload but he is gave invalid file.
        gave my your email to send this file if you want
        Kind regards
        jamal
        • #49
          hi max
          Kind regards
          jamal
          Compress it to a zip file. Then you will be able to upload it.
          Also, try to output the file from AutoCAD to a more general format, such as PDF or JPG. Then everyone can read it.
          • #50
            this is diagram
            jamal...........
            • #51
              gs4
              HI MAX
              where are you....................
              can you used a circuit to assigning
              volume or depth from through the outcomes for (MA).as E.G
              • #52
                HI MAX
                • #53
                  gs4
                  hi max
                  must claim your god to point
                  out to solution the troubles
                  jamal
                  • #54
                    hi max
                    jamal
                    Hi Jamal,
                    the readings of ma meter about detection are not important... most important is sound in GSIV, you have to hear sound and any , even small, increase in pitch means you detected something...
                    Of course, the more the pitch increase (higher frequency) the more the target is either near or big ... so produce eddy current signal detected by device.
                    As said, the GSIV have problems with hot rocks and not perfect flat-soil-composition... so if there are e.g. fired ceramics is a big trouble.
                    The detection range vary depending of your setup... usually GSIV is better equipped with 8'' round coil... but several variations could be made e.g. for depth PI adaptation of it... that way is also invaluable tool too.
                    I don't understand your reference to VLF443 and schematic... where's the problem ?
                    Kind regards,
                    • #55
                      hi max
                      I want search off box (60 *40*40) under depth 2.5 M .
                      which the design . can your advise my to made it . in this forum
                      2) about VLF 443 I connected all cables but I do not confirm from it correct.
                      3) for GS4 I am question , for internal circuit in red circuit in illustrated attached .
                      you have diagram, written on any program for schematic design.
                      jamal....
                      • #56
                        hi max
                        i am to bide one's time....
                        and i am await your...
                        you have diagram, written on any program for circuits design .
                        and question about control panel what is the consist of (switchs & variable resistant)
                        jamal....
                        submit message
                        • #57
                          GoldScan 4
                          Dear Max
                          Thanks for ur guide around Goldscan.I saw u made it!
                          what's Depth spicifications of Goldscan?
                          Have u PCB and full part list?
                          thank u and goodluck
                          • #58
                            THEY IS BETTER GOLDSCAN 4 FROM THE DELTAPULSE?
                            HELLO.
                            I WANT TO MANUFACTURE GOLDSCAN 4.
                            THEY IS GOOD LOCATOR?
                            IT HAS GOOD RECORDS?
                            I MANUFACTURED THE DELTAPULSE,
                            I REQUEST WHOEVER KNOWS, IT HELPS ME.
                            I THANK.
