MD Compare test chart
  • MD Compare test chart
    VLF METAL DETECTOR TESTS - WHAT IS THE BEST ?
    METAL DETECTOR TESTS FOR DEPTH RESEARCH (second page)
    By Alain Châtillon, Président Latincom-Mex SA & Deepers Detector Co Email : [email protected]
    IMPORTANT OBSERVATIONS :
    Air testing test all metals normally gives much greater distances than those obtained in the ground test. Certain apparatus lose up to 13 cm between both, but when the detector gives a very good result in the air, it is generally - to a lesser extent - is powerful in the ground test, too.
    The Ground Test for all metals is performed in a mixture of 50% bio-soil and 50% mineralized river sand, each moistened and measured before each test. Adjusted at maximum capacity many apparatus become unsteady (above all the ones with metal casings which tend to self-detect from a certain range on).
    Excellent notation for the Garrett GTI 2000, easy usage, stable electronics, clear responses, good ergonomics, casing ABS, battery compartment as far from searchcoil as possible. Very good results with Fisher CZ20 (though a bit heavy). The Discovery Baron base module also gives reliable results. With its finest adjustment, the White’s 6000 Di Pro offers good detection depth but becomes rapidly unsteady. The Minelab Sovereign XS-2 works very correctly but uses up battery power in no time. Special mention for the Tesoro Lobo Super Traq, a very steady apparatus and which should give the best performances with a round searchcoil 10 1/2" (which we haven’t been able to test).
    Thanks for your comments. Next test : Pulse Induction and 2 boxes
    TARGET $25 CENT (Ø 24 mm Cu)
    DETECTION TEST
    DETECTOR MODEL
    Ø SEARCHCOIL
    ALL METALS
    AIR
    GROUND
    Garrett GTI 2000
    91/2 "Super Deepseeking
    37 cm
    25 cm
    Treasure Ace 300
    81/2" Grossfire
    17 cm
    13 cm
    Garrett GMH CXII
    81/2" Grossfire
    24 cm
    18 cm
    Garrett GTA X 1000
    81/2" Grossfire
    25 cm
    17 cm
    Garrett GTA x 500 ***The best small device 81/2" Grossfire
    26 cm
    21 cm
    White’s SpectrumXLT
    91/2" Blue Max
    30 cm
    21 cm
    White’s 6000 Di Pro
    91/2" Blue Max
    35 cm
    22 cm
    White’s Quantum XT
    91/2" Blue Max
    26 cm
    20 cm
    White’s Classic SL III
    91/2" Blue Max
    24 cm
    15 cm
    8" Blue Max
    19 cm
    14 cm
    Fisher 1225 X
    5"
    17 cm
    12 cm
    Fisher 1235 X
    8" Spider
    21 cm
    16 cm
    Fisher 1265 X
    8" Spider
    25 cm
    17 cm
    Fisher 1266 X
    101/2" Spider
    29 cm
    19 cm
    Fisher CZ5
    8" Spider
    32 cm
    21 cm
    Fisher CZ20
    101/2" Spider
    36 cm
    24 cm
    10" x 5" elliptical
    28 cm
    20 cm
    Tesoro Toltec
    101/2"
    26 cm
    18 cm
    TesoroGolden Sabre
    8"
    21 cm
    16 cm
    Tesoro Bandido
    8"
    22 cm
    14 cm
    Tesoro Silver Sabre
    101/2"
    24 cm
    17 cm
    Tesoro Sidewinter
    8"
    20 cm
    16 cm
    Tesoro Cutlass
    8"
    19 cm
    14 cm
    Tesoro Amigo
    7"
    17 cm
    13 cm
    Discovery Baron Module base
    8"
    32 cm
    23 cm
    8"
    24 cm
    18 cm
    71/2" , waterproof
    26 cm
    19 cm
    10", waterproof
    33 cm
    22 cm
    Pulse Induction and 2 box machines
    COMPANY
    TYPE
    TYPE
    HEAD
    (searchcoil or loop)
    DEPTH AT WHICH A CAN OF SODA CAN BE DETECTED
    12 x 6,5 cm - 78 cm2
    DEPTH AT WHICH A METAL GALLON JUG CAN BE DETECTED
    400 cm2
    DEPTH AT WHICH A METAL 2 1/2 GALLON JUG CAN BE DETECTED
    650 cm2
    MAXIMUM DISTANCE ABOVE GROUND FOR DETECTION FOR A METAL 2 1/2 GALLON JUG
    Gemini III Fisher
    Two box detector
    45 cm
    70cm
    80
    Little signal strength more than 80 cm
    TM 800 White’s
    Two box detector
    40 cm
    65 cm
    70
    Weak signals at more than 75 cm
    TF 900 Discovery
    Two box detector
    45 cm
    65 cm
    75
    maximum at 120 cm
    Série CX Garrett
    Two heads depth multiplier
    40 cm
    55 cm
    65
    Little signal strength at more than 65 cm
    Deepstar **
    Round Searchcoil
    42 cm
    60 cm
    No signals further than 80 cm
    Pulse Star II ***
    Loop 1 m x 1 m
    48 cm
    85 cm
    115 cm
    160 cm
    MD8 ***
    Elliptical head
    48 cm
    85 cm
    90 cm
    No signals further than 90 cm
    Lorenz 5
    Loop 1.25 m X 1.25 m
    50 cm
    95 cm
    120 cm
    140 cm
    Good information , NELSON !!! It is always good to have field tests here on this forum . Especially soil , mud "DIRT" tests....Did you see the excellent report of the Garrett GTI-2000. No wonder Garrett discontinued and Pulled that Detector off the Market fast , It's cost was over $200.00 less than the GTI-2500 and worked just as Good !!!!....Garrett was going crazy when the GTI-2000 was selling faster than the GTI-2500. American business Practices and Philosophy. Oh by the way , how is the $$ U.S. dollar doing ????.............I try very hard to stick to the topics , have you noticed ????......................Eugene
      I can't understand how they determine the max depth in the ground!!!!!
      Does they put a coin in difference holes at 16... 17... 18...19 cm etc
      I need your opinion
      It is not the same if you put soil between coil and object, and if you put the coin inside the soil...........
        Hello everyone , Good point GEO. Then that is not the maximum depth !! What if you buried a Roll of coins at 20 centimeter's more depth , some machines will detect and some will not !!! So one coin buried does not tell us a Detectors MAXIMUM RANGE. Here is my favorite Depth Test Web-Site !!!...............Eugene.... http://wwwdark.w.interia.pl/testy.htm
          I also use the same site for read depth tests
            Hi Eugene, yes this reports gave me an idea about CZ-20 performance, plus other reviews that i saw on the net.
            About CZ-20 i m very satisfied with it. Excellent machine, good discriminston, good deep and good batterie drain.
            Works very good on all soils.
            About dollar, don´t understand what are you talking about.
            Nelson
              i working gti 2500 ifound the towin loop one iron box in deep 3meter.i fond the silver 20cm.25cm a loop bluemax1.80cm.
