VLF METAL DETECTOR TESTS - WHAT IS THE BEST ?
METAL DETECTOR TESTS FOR DEPTH RESEARCH (second page)
By Alain Châtillon, Président Latincom-Mex SA & Deepers Detector Co Email : [email protected]
IMPORTANT OBSERVATIONS :
Air testing test all metals normally gives much greater distances than those obtained in the ground test. Certain apparatus lose up to 13 cm between both, but when the detector gives a very good result in the air, it is generally - to a lesser extent - is powerful in the ground test, too.
The Ground Test for all metals is performed in a mixture of 50% bio-soil and 50% mineralized river sand, each moistened and measured before each test. Adjusted at maximum capacity many apparatus become unsteady (above all the ones with metal casings which tend to self-detect from a certain range on).
Excellent notation for the Garrett GTI 2000, easy usage, stable electronics, clear responses, good ergonomics, casing ABS, battery compartment as far from searchcoil as possible. Very good results with Fisher CZ20 (though a bit heavy). The Discovery Baron base module also gives reliable results. With its finest adjustment, the White’s 6000 Di Pro offers good detection depth but becomes rapidly unsteady. The Minelab Sovereign XS-2 works very correctly but uses up battery power in no time. Special mention for the Tesoro Lobo Super Traq, a very steady apparatus and which should give the best performances with a round searchcoil 10 1/2" (which we haven’t been able to test).
Thanks for your comments. Next test : Pulse Induction and 2 boxes
TARGET $25 CENT (Ø 24 mm Cu)
DETECTION TEST
DETECTOR MODEL
Ø SEARCHCOIL
ALL METALS
AIR
GROUND
Garrett GTI 2000
91/2 "Super Deepseeking
37 cm
25 cm
Treasure Ace 30081/2" Grossfire
17 cm
13 cm
Garrett GMH CXII81/2" Grossfire
24 cm
18 cm
Garrett GTA X 100081/2" Grossfire
25 cm
17 cm
Garrett GTA x 500 ***The best small device 81/2" Grossfire 26 cm
21 cm
White’s SpectrumXLT 91/2" Blue Max
30 cm
21 cm
White’s 6000 Di Pro 91/2" Blue Max
35 cm
22 cm
White’s Quantum XT91/2" Blue Max
26 cm
20 cm
White’s Classic SL III91/2" Blue Max
24 cm
15 cm
White’s Classic SL II8" Blue Max
19 cm
14 cm
Fisher 1225 X
5"
17 cm
12 cm
Fisher 1235 X8" Spider
21 cm
16 cm
Fisher 1265 X8" Spider
25 cm
17 cm
Fisher 1266 X101/2" Spider
29 cm
19 cm
Fisher CZ58" Spider
32 cm
21 cm
Fisher CZ20101/2" Spider
36 cm
24 cm
10" x 5" elliptical
28 cm
20 cm
Tesoro Toltec101/2"
26 cm
18 cm
TesoroGolden Sabre8"
21 cm
16 cm
Tesoro Bandido8"
22 cm
14 cm
Tesoro Silver Sabre101/2"
24 cm
17 cm
Tesoro Sidewinter8"
20 cm
16 cm
Tesoro Cutlass8"
19 cm
14 cm
Tesoro Amigo7"
17 cm
13 cm
Discovery Baron Module base
8"
32 cm
23 cm
8"
24 cm
18 cm
Minelab Sovereign XS71/2" , waterproof
26 cm
19 cm
Minelab Sovereign XS-210", waterproof
33 cm
22 cm
Pulse Induction and 2 box machines
COMPANY
TYPE
TYPE
HEAD
(searchcoil or loop)
DEPTH AT WHICH A CAN OF SODA CAN BE DETECTED
12 x 6,5 cm - 78 cm2
DEPTH AT WHICH A METAL GALLON JUG CAN BE DETECTED
400 cm2
DEPTH AT WHICH A METAL 2 1/2 GALLON JUG CAN BE DETECTED
650 cm2
MAXIMUM DISTANCE ABOVE GROUND FOR DETECTION FOR A METAL 2 1/2 GALLON JUG
Gemini III Fisher
Two box detector
45 cm
70cm
80
Little signal strength more than 80 cm
TM 800 White’s
Two box detector
40 cm
65 cm
70
Weak signals at more than 75 cm
TF 900 Discovery
Two box detector
45 cm
65 cm
75
maximum at 120 cm
Série CX Garrett
Two heads depth multiplier
40 cm
55 cm
65
Little signal strength at more than 65 cm
Deepstar **
Round Searchcoil
42 cm
60 cm
No signals further than 80 cm Pulse Star II ***
Loop 1 m x 1 m
48 cm
85 cm
115 cm
160 cm
MD8 ***
Elliptical head
48 cm
85 cm
90 cm
No signals further than 90 cm
Lorenz 5
Loop 1.25 m X 1.25 m
50 cm
95 cm
120 cm
140 cm
