Originally posted by nelson
View Post
Pinpointers TOPIC
THanks kt315.
But, has i understand the below schematic does not belong to Automax.
My question refers to the schematic show below.
Nelson
Originally posted by kt315 View Postit is Automax Precision V4 schematic. I have give a bunch of the schematics and all are standart type one like to Automax.Attached Files
Originally posted by nelson View PostHi. Does anyone made this pinpointer?
What about distance range for coins?
I m drawing a small pcb for it.
Nelson
I made all I think!
Uhm.... yes... but I made on veroboard-like stuff not real pcb... no need of that mess for such an easy stuff!
But where do I put that things ??? Forget about everything!!!
I found just one ! Dang!
Kind regards,
it's not mine. as you may note this is done on standart components.Attached Files
I had build this pinpointer yesterday and is still under test.
So far is detecting a 22 mm copper coin at 2,5 cms,; a small screw from his head at 1 cm.
Now i m asking about the ferrite coil, where i should play to take or put more turns to get more sensitivity, L1 or L2.
Nelson
Originally posted by Max View Postseems interesting...Attached Files
Hi...
I saw this detector...Can I use this machine a pinpointer.It seems good...What do you say its about?
Link: http://www.micro-examples.com/public...odetector.html
Regards...
Look here. This is easier and distinguishes metals.
http://www.md4u.ru/forum/viewtopic.php?f=8&t=3602
Originally posted by Eddy71 View Post
"Over the bucket will not say.Do as pinpointer for small coins in the sandbox search.I think if you attach a larger diameter coil will be as TrekerFM. So in a branch about to answer it. First Source here:
http://vrtp.ru/index.php?act=categories ... nWhat is the Russian-language program for the controller does not know - I wrote it in English
As for selective impulsnika until soon, not until the summer - in time for work .. Dam And there is much to be pereprbovat. I want from the complexities of the coil to move away. So that was a bit more room, but not "up to a millimeter."With the collapse of the Union with a wire winding issue. . It is not always possible to find exactly edakii, especially in remote areas .."
Does it mean that you wrote the source with comments in English?
To download the link above one need to be registered....
I'm aware that hex code is available, but I'd like also to understand the principle on which it works. For example the Tracker FM (if I remember correctly) has a 555 to make the coil oscillate and the micro detects frequency variations as in a BFO MD, while yours has the LC circuit directly connected to the micro pins.
This pinpointer works on the same principle as TrackerFM. Only much easier to manufacture. Nice for beginners.
Sensitivity at 14 cm coil in a large metal approximately 0,5 m.
Copper coin 25mm sees with coil diameter of 70mm at a distance of 65mm.
For LC oscillator using an internal comparator of the controller.
The pages filled md4.ru 5 different versions of the firmware - for different coils can be chosen.
Its name in English "Babe FM"
Originally posted by Eddy71 View PostThis pinpointer works on the same principle as TrackerFM. Only much easier to manufacture. Nice for beginners.
Three more questions:
1- How use the push bottom "Calibrate",
2- Can you give us the caracteristic of the coil( diameter,mH, wire size) , can we use one rod coil for example?.
3- Is it normal when when you put on the power, in the first time the buzzer make one sound, and after each 10 secondes this sound is repeating. And there no effect when you pass one metallic object over the coil ( my coil: diam 70mm, 1.45mH, wire diam 0.315mm).
Waiting for your comments
All the best.
Luc
If the calibration failed, the error signal in a buzzer. This means the frequency of LC is not stable. It can be if power is not from the battery or coil are not shielded or bad capacitors 100 nH
Originally posted by Eddy71 View PostIf the search appliance starts to give false signals (frequency of the LC has changed for whatever reason) should press the button "Calibrate"
The main characteristics not the coil. More importantly tuning frequency LC. It should be within the range 18-19 kHz. (Measured at 5-th pin of controller)
The first "beep" sound - indication of the power on and the beginning of calibration. If the calibration is successful, the other sound (like the sound of flying arrow).
Thanks Eddy, sorry for my late answer, I was out for few days, I will try your comments, and I will keep you advice.
Thanks again
Luc
