datasheet request
  • datasheet request
    hi, can anyone give me datasheet on obsolete AD513? thanking in advance.
    please I do not need in AD515-518 one, etc.
    datasheet request
    Kt315 , I am searching . AD513 . Is it an op-amp , or for digital control / potentiometer , or used in an old video recorder ???................Eugene
      it's a fast op amp, with high slew-rate:
      Part Number = AD513JH
      Manufacturer Name = Analog Devices
      Description = Single General Purpose Op Amp - FET input, High Spd
      Input Bias Current Max. (A) = 30p
      Unity Gain BW (Hz) = 1.0M
      V(io) Max. (V) = 50m
      I(io) Max. (A) = 20p
      Com Mode Inp Range (VICR) = 20
      Input Resistance Typ. (Ohms) = 100G
      Temp Coef. of VIO = 75u
      P(D) Max.(W) Power Dissipation = 210m
      Nom. Supp (V) = 15
      Status = Discontinued
      Package = TO-99
      Pins = N/A
      Military = N
      Slew-rate is 50V/us. Could be used in the 10Mhz range of freq.
      The russian crossref is probably the 574УД1.
      Part is discontinued many years ago, that's why AD removed it from obsolete parts database, so it's very difficault you'll get its datasheet at now. But maybe informations provided are enough...
      Kind regards,
      Max
        people, thanks lots for the help.
        yours
          HI Kt315,
          http://www.sierraic.com/pnresults.asp?navpart=AD513
            sorry
            Hi Kt315,
            well the pdf doesn't work sorry.
