Help needed
  • Help needed
    Could anyone help me please with the voltage specs of the toggle switch on the Euro sabre.The switch i need the info on is the following.
    It's the; Iron Blank-Off-Iron I/D ,3 locking postion toggle
    I enquired about a switch from a wholesaler,ad was given this reply
    Thank you for your enquiry.
    the function is the same however you have not advised what voltage is the original switch and if the positions are momentary or latching. The switch we sell is a latching switch which means it does not spring back into the off position once you take your hand off the switch and rated at 250v ac. If this is the same then you can look at this product as a possible alternative.
    If you require any further details, documents or advice please do not hesitate to contact our Technical Helpline.
    Yours Sincerely
    This is my switch
    Many thanks for any help you can give
    Ash
    Yours Sincerely
    This is my switch
    Ash
    This is an ON-OFF-ON (locking both ways, centre off) SPST switch. You can get one from Maplin Electronics here -> http://www.maplin.co.uk
    It looks like the sub-miniature type B. Part number: FH01B.
    Unfortunately you'll have to search from the main Maplin page, as the page must be generated on the fly, and the direct link doesn't work.
      Many many thanks for your help
        You are welcome.
