Hi all, I'm having a problem with my original Soveriegn. What's happening is the threshold hum is going beserk. It will go from a nomal sounding threshold to a low sounding deep buzz and then back to normal. At first I thought it was my battery so I went to the 8 AA pack, thought that fixed the problem but it did not. Thought it might be the coil so I switched coils, same problem. The problem started when I hooked up a SunRay meter, I'm pretty sure this is just coincidence and not the cause of the problem. I've got the control box off and just hooked up the coils straight to the box and I'm still having this problem, tried all different sens, settings and disc settings. The threshold seems fine until you pass a target over the coil, it detects the target fine, but after the target is not under the coil anymore that's when the threshold starts to go crazy, going from normal threshold tone to the low sounding deep buzz then back back and forth between the two. I'm really bummed out as I just got this detector a few weeks ago, then I bought a new 8" coil , SunRay meter and a new straight shaft mod with the SunRay meter mount. So now I'm in almost $600 for this outfit. Would sure appreciate any advice.
Thanks,
Gary
Thanks,
Gary
