Can anyone tell me what is the maxium voltage that you can be run on the SD2100? I have read you can push it to 8.3 volts to increase depth efficiency without frying the circuit board although I have not seen any mods for doing this.
At present I'm running a SD2100 with the CoilTech 12v-7.3v regulator & looking at seeing if it is cost effective to mod the machine to improve the depth efficiency rather then upgrading to a later model. Any advice would be appreciated.
Cheers
Ted
Cheers
Ted
