Hi Dennis
The symptoms with metal package type TX oscillator transistors were when touching knobs, housing wires within the detector and external coil lead was getting signal break through ie falsing.
When I first made the project had used plastic types, only changed to metal to see if it would give me a little more gain on depth, so basically copied the original transistors from tesro.
It was at that point I had created the problems related to on here, so once changing back to plastic all those problems went away.
You will find that just touching or moving wires anywhere near those metal type transistors will cause the machine to go unstable but again when plastic type are fitted no problem.
Did mention this many moons ago but has got buried amongst hundreds of posts in the original forum.
