New PI technology proposals.
  • Hi Aziz,
    So where does the energy go?
    Eric.
      Not necessarily. As I stated before, provided the downward current (field) ramp takes place in 1/10 of the target time constant, ...
      Ferric Toes
      On that note... Is there a published set of general TC ranges for different target types? What little information that I have come across varies greatly depending on the source. I have a suspicion (and some data from experiments that suggest this) that the TC is dependent on more than target composition (e.g. size, shape). What I am looking for is something that gives a reasonable range of TC's for the types of targets typically sought by hobbyist metal detectors. I have a 14K gold band that appears to have a TC of ~6-9usec (I am working from memory at the moment). What TC ranges do we need to be concerned with?
      • Hi Eric,
        Hi Aziz,
        Eric.
        this is really a very very interesting question. At the end, the magnetic field energy must be converted to heat in the matter of the surrounding coil and/or an electro magnetic field emission will occur.
        Is this correct? I don't know, what exactly happens.
        Aziz
        • radiated
          The energy is radiated as Electromagnetic Energy.
          Of course the Electromagnetic Spectrum includes
          Infrared Radiation (heat) and Radio Frequency Spectrum.
          Some energy would make the targets heat up by virtue of
          eddy currents, some would make the coil heat a bit, the rest
          radiates into the surroundings and into space, where the aliens
          could receive it on their super sensitive receivers.
          • Energy
            The voltage on a capacitor = Q/C volts
            The energy in a capacitor = 1/2 C V^2 Joules
            where Q = charge in Colombs
            C = capacitance in Farads
            V = voltage in Volts
            Take two capacitors both with value = 1 Farad
            One capacitor in charged to 10 volts
            It has a charge of 10 Colombs
            The energy in this capacitor is 50 Joules
            The other capacitor is uncharged
            It has a charge of 0 colombs
            The energy in this capacitor is 0 Joules
            The leads of the capacitors are shorted together
            transfering 1/2 of the charge to the uncharged capactor.
            The voltage of each capacitor is now 5 volts
            Each capacitor has a charge of 5 Colombs
            The energy in each capacitor is 12.5 Joules
            If You add the energy of both capacitors you get 25 Joules.
            Conservation of Energy says we should have 50 Joules
            Where did the other 25 Joules of Energy go ????????
            The capacitors are ideal and have no resistance
            None of the energy is dissapated as heat in this example
            and would be small anyway.
            A similar example could be made with inductors/coils but
            capacitors are easier for everyone to understand. Usually.
            So where did the other 25 Jouldes of Energy go ?????????
            (Not a trick question and can be found in Physics books)
            • Originally posted by JC1 View Post
              You described a physically impossible circuit. When you connect the two capacitors, if you have no resistance, the current would try to go to infinity. What would happen realistically is that then those "no-resistance" wires would become inductors (even though small inductance, no problem if current trying to go to infinity). So the circuit would oscillate, and the missing energy is in the mag field of the inductor. Probably already answered by someone else.
              Radiation would also eventually settle the response down to end state, as Qiaozhi noted.
              Last edited by simonbaker; 12-17-2008, 10:28 PM. Reason: typo fix, acknowledge later post.
                This interesting question is commonly known as "the two-capacitor problem".
                The usual answer is that the energy is lost in parasitic resistance, ESR of the capacitor, and/or arcing at the switch. I note that you stated the capacitors in your example are ideal and have no resistance, not that the switch or wiring has no resistance. But, if we assume that all these loss mechanisms are negligible, then the only thing left is radiation (EMI), as the two capacitors will act as a loop antenna. However, if the energy is primarily lost in the resistive elements, then this loss is independent of the value of resistance.
                  Not necessarily. As I stated before, provided the downward current (field) ramp takes place in 1/10 of the target time constant, then the object is fully stimulated. Designing for a higher flyback voltage and faster switch off will not get you any more signal. Very high flyback voltages have their own problems. i.e very high peak currents in the RX input clipping diodes, and input resistors working outside their voltage ranges. I had an input resistor fail on an early Goldscan for this reason. It didn't fail completely, it just went horribly noisy.
                  Basic PI theory can be considered by just examining one step in a magnetic field. If a field has been set up for an infinitely long time and then reduced to zero in a infinitely short time, we can see what happens in a conductive object within that field. All the time the field is static, then nothing happens within the object. As soon as the field starts to change, then eddy currents will be generated which try to maintain the field within the object at its pre-switch off value. These eddy currents first flow on the objects surface, and then gradually diffuse inwards, until for times after one time constant, they become exponential. This diffusion is caused by the object's resistance that cause the eddy currents to lose energy (heat loss). Eventually, there is no internal emf and hence no current and the field and object become static again. In this theoretical consideration the initial field could be generated by means other than a coil of wire carrying a current. Something to ponder on during the upcoming holiday period - if a long standing magnetic field (not coil generated) is instantaneously switched off in free space with no conductive objects nearby, is there a flyback voltage?
                  Eric.
                  It's called a generator with permanent magnets!
                  You said something earlier that was interesting, that if the time constant of the target is slow, then there is a point where turning off the TX current faster doesn't make a difference. It seemed intuitive to me, sort of like removing the force from an object that swings back at its own rate.
                  I'd like to remind myself better though. It's tempting to think that when the TX coil turn-on phase reaches a steady current, that the target reaches a steady current also. Typically not, of course. As the di/dt of the TX coil diminishes to zero, the current amplitude in the target diminishes to zero.
                  Now, turning off the TX coil current gives the infamous pulse, which will stimulate a current in the target. Here is where I think it gets complicated.
                  For long time constant targets, I think it may be useful to think in terms of "delta functions" (infinitely high, zero width, but finite energy). Like striking a pendulum with a hammer -- the blow is over in an instant, but the amplitude of the response depends on the energy of the strike. If the blow is twice as long (still very quick) but half as hard, the pendulum swings the same.
                  The point of that analogy is that if we turn off the TX faster, we may stimulate a higher pulse in the target, but for shorter time and perhaps no more energy! The end response may be essentially the same if the target is a "slow responder".
                  Now for faster targets this could be different -- they tend to follow the pulse more closely. However, the time constant of our RX receive coil may itself have a slower time constant than the target and therefore not respond much differently to a fast current pulse in the target versus a slower one. The target magnetic field in that case looks like the hammer blow to our RX coil!
                  More food for thought anyway.
                  Cheers,
                  • Hi friends,
                    I will be offline for some days. My harddisk in my PC got broken one hour ago. I have lost at least 3 weeks of work (also some SPICE files). Fortunately, I made a total backup of my harddisk three weeks ago. So it will delay, until I have a new harddisk and make a fresh new system.
                    I am using now back-track 2 (Linux) on my USB-stick.
                    So don't wonder, when I am not available.
                    Aziz
                    • analogy
                      Hi simonbaker,
                      Good Analogy on the fast turn off,
                      You are right about the oscillations on the capacitors too.
                      Hi Qiaozhi,
                      You are right as well, radiation was my point.
                      do this near a radio and you may get to hear it.
                      I got on the web and took a look at what I could find on this "classic" problem.
                      found a bunch of stuff. Google two capacitors energy go
                      Problem - Charging or discharging a capacitor may cause energy loss even if no dissipative elements are apparent.
                      Relevance - The problem affects power-loss and efficiency, electromagnetic interference (EMI), contact arcing, power MOSFET drive circuits, snubbers, solid state relays, resonant and duty-cycle switching converters, clocks, and selection of circuit topology.
                      Solvability - By transferring energy through an inductor or by controlling the charging waveform, a capacitor can be charged without loss of energy (ideally).
                      Solution - Transfer energy through an inductor or with a resonant or sinusoidal waveform with switching at zero voltage.
                      Personal - A personal anecdote.
                      On the Web - Additional information on the Web.
                      References - One to a few key papers.
                      Where the energy went.
                      Loss. The energy lost in directly switching voltage to a capacitor at another potential is lost in parasitic resistance, and if the resistance is too low, in arcing or welding of the switch contacts or in radiation.
                      Resistance. The easiest loss mechanism to show analytically is the loss in parasitic resistance, such as the capacitor equivalent series resistance (ESR) or wiring resistance. Adding this resistance to the circuit and calculating the power dissipated shows the energy loss. The energy loss is independent of the value of the resistance.
                      Arcing. Most switches used in power supplies are solid state and arcing is not a problem, but if a capacitor is charged through a contact, arcing may be a problem.
                      Radiation. High rates of change of voltage or current result in radiation. Directly switching voltage to a capacitor at another potential is a source of radiation (EMI).
                      The problem in Figure 1 on what happens to the energy when a charged capacitor is switched into another capacitor at a different voltage was a homework problem in my first circuit course so I learned about this early. However, I am constantly amazed at how often such a power electronics "perpetual motion machine" circuit is proposed as an efficient converter.
                      The most flagrant example I know about was on a three-year government project to make a highly efficient hybrid dc-dc converter using only capacitors and no inductors. When the first paper was given at a respected conference, several from the audience commented on the problem -- suggesting that it was inductance in the banana-plug-wired breadboard that made the circuit work. Undaunted, they reported on circuit improvements the next year, still with their banana plug breadboard. Their plans were to make it a hybrid circuit next year. Next year there was no paper. We speculated that when they finally got rid of wiring inductance, they found the circuit did not work, more than two years after it was obvious to experienced power electronics designers. In all fairness, this was in the mid 1970's and even major power supply companies were having problems with switching-mode power supplies. Concurrently, the sponsoring activity was doing some outstanding work in the field. The lesson-to-be-learned is that when someone questions your work, you should seek a side meeting to explore their concerns - they may know something you need to know. In this case it would have saved going down a blind path.
                      http://www.smpstech.com/charge.htm
                      Reflections on the lost energy when two
                      capacitors are connected, or two masses collide, or
                      similar problems, suggests a new law of nature:
                      that stored energy of one kind cannot be
                      transferred without loss unless it undergoes a
                      change in energy form in the transfer process.
                      Many physics and circuit theory textbooks describe
                      the well-known but curious phenomenon of two
                      capacitors with a switch between them.
                      Lossless energy transfer possible, but on one
                      condition
                      Note that initial boundary incompatibilities could
                      also be resolved (and modelling rules complied with)
                      by adding non-energy-dissipating model elements.
                      In the two capacitor case, an inductor, for example,
                      would allow energy to flow from the capacitor into
                      the inductor, and so into the second capacitor, in a
                      lossless way, with the energy accounts balanced at
                      every moment. (Note also the physical justification
                      for this addition, since all real circuits have
                      inductance.) This causes a change of energy 'type'
                      (from capacitive to inductive, or from electric to
                      magnetic) of precisely the kind referred to in the
                      Lacy–McCabe law. The only circuit element that
                      would not resolve the incompatibility would be
                      another ideal capacitor, which again would
                      constitute an attempt to violate the Lacy–McCabe
                      law.
                      http://www.iop.org/EJ/article/0031-9...0-289aa8a9c985
                      • dc-dc converter
                        Interesting about dc-dc converter problem using only capacitors.
                        I worked on that myself. While not lossless, you can can do pretty well by putting a bunch of capacitors in series, charge them up, then reconnect them in parallel for a lower voltage. Or the reverse. Called "charge pump".
                        You can buy chips that do that, albeit much more sophisticated than the design I was trying.
                          This is a simple limit problem. If you connect the caps with a resistor, the energy is (obviously) lost as heat in the resistor. As you take the limit R ─> 0, you'll find that I ─> ∞ but that the energy loss is constant. So, in this example, 0·∞ = 25 J.
                            And even if you make the wires zero length (in an attempt to get rid of inductance), I'll bet the capacitors become resonant cavities (assuming non lossy dialectric like vacuum) and will still oscillate. So as R -> 0, the energy loss is constant, but the time constant will go to infinity too -- it will take infinitely long time to dissipate the energy (neglecting radiation)!
                            Let's try it...
                            Cheers,
                              Cheers,
                              G`day Simon
                              I must say i share the same thoughts as you on this point in regard to the relationship between the slew of the step response and the resulting eddies on targets.I think the amount of time that a target is exposed to a collapsing coil field is to important to be dismissive of it.
                              Slow targets by there very nature must tell you that they need more time exposed to a collapsing coil field in order to get maximium target stimulation,just like the inductance of a coil when one needs more time to build the current up.
                              The targets of interest with me are large nuggets from 1 oz to hundreds of ounces,these nuggets are full of surface irregularities and one would think that to some extent the eddies on the surface of these nuggets would cancle or oppose each other to some degree and there for resist the growth of eddies.
                              "inductance".
                              Zed
                              • Hi friends,
                                I can confirm this, that a longer lower target stimulation has some more advantages than a higher and shorter target stimulation.
                                As we integrate over some period, the total acquired signal is more and has lower noise. There is another disadvantage of higher and shorter target stimulation: we can not process the signal on the coil at this time (high voltage). The recent SPICE simulations showed this elegantly. Unfortunately, they have gone to the hell and I have lost these files yesterday.
                                Anyway, as soon as my new system is finished, I will remake all the SPICE files and will show you some very interesting results. The SPICE files will be posted here to have also a backup.
                                Interesting discussion about the energy. We can not create or destroy energy. All what we are doing is converting it. So the total amount of energy isn't lost. It is converted.
                                Aziz
