I will give you some more benefits to coil configurations with this universal design:
1. DD coil configuration.
TX Tesla coil as described above and seperate RX coil which are inductively decoupled to each other (k=0). In this case, we can sample just-in-time of the target signal response. Provided that the balance of the coil is perfect enough, that the clamping diodes will not clamp or clamp for a very short time period due to lower breakdown overvoltage.
DD coil configuration makes the power supply consideration easy due to galvanic decoupling of the RX coil.
2. Transformer coupled MONO coil configuration.
A small inductor (few turn windings) with small inductance is for the magnetic field energy generations. This coil need no damping resistor. It will be fired from the MOSFET. A big inductor with higher inductance of the same size and position (coupling k=1) with his damping resistor on ends is for target signal stimulation and is working as a receive coil. We have a typical transformer coil of the same size and position. Low windings to higher windings step-up transformation. Both coils are not splitted but galvanic seperated.
So power supply can be realized easy. We will have lower flyback voltage (flyback of the primary TX coil is not added).
3. Split coil (Tesla coil) MONO coil configuration.
Introduced allready above.
4. Alternating magnetic field excitation configuration (MONO/DD).
We need a symmetrical center-tapped TX coil, which the both coil ends will be driven individually from the MOSFET in alternating sequences. We have two MOSFET switching drivers. Signal can be taken as usual on both ends. The damping resistor is placed on both ends.
You see, there are many different configurations that can be made with this simple design.
