Got a XP ADX250 and noticed that mainboard and microchip (V4) are exactly the same as the XP ADVENTIS II. Only difference is that the groundbalance pot is missing on the ADX250. The mainboard is 100% ready to add this potentiometer and the case has also a predrilled hole behind the frontlayer.
Just need to know what value this potentiometer must be?
Is there someone with a Adventis II and willing to check the value of his groundbalance potentiometer? The case opens very easy: remove the wreck from the connector at the bottom en gently remove the 4 screws at the front of the case. Then it opens easy without any harm.
When I got it's value I will solder it into my ADX250 and make it to an ADX250 with groundbalance like an ADVENTIS II. I think it's worth trying................
Thanks for any information!
Michel.
Michel.
