....well I found another spare 20 minutes and it seems there has been bit of discussion going ... all good stuff.
Anyway to answer quickly the questions about the 4066 driver cct ...
It does actually work
below is the output of channel 1 with about a 40 uS delay after first turn off the green trace is the input to the 4066 ... white trace is the sampled output ... the timing is set to intercept the decay slope at about 75 %.
and here is the breadboard with 60 turn 'boss' differential coil. Note he circuit here is built with a balanced FET driver. Because of the number of turns in the coil it is very sensitive to Earth's magnetic field. However it is also very sensitive to targets even very small ones though the sample is out at 40uS.
... Hey Aziz when I get more time we proceed OK ...
Cheers from moodz
Cheers from moodz
