March 24 marked the 10th Anniversary of the Geotech forums. Thanks to everyone who has participated over the years!
I wanted to kick off this contest on the anniversary date but was traveling then, and got busy since.
But now it's time! Here are the rules:
What do you win? A t-shirt? A certificate suitable for framing? Heck no, how about...
Your choice of a White's TDI Pulse Induction detector or a White's Spectra V3 detector !
Final rule: winner must agree to allow actual name to be used in the winner announcement.
- Every post counts as 1 point.
- Every new thread-start counts as 2 extra points (3 total).
- Posts such as "Attaboy!" and "Thanks!" will not count.
- You must be a registered user and post under your own ID. If you accidentally (or intentionally) post as unregistered I cannot count those posts.
- Points will be totaled from March 24 through July 24.
- Points count as "entries" to a final drawing. If you end up with 50 points, you will have 50 entries into the drawing.
- I will physically print all entries onto small slips of paper using your ID number. If you have 50 entries then you will get 50 slips of paper. I will then put them all in a box and have an independent person draw a paper slip. Winner!
