Variable Coil Current Control
  • #31
    Heres a cct that i have been playing with,i use the mosfet to regulate the current flow and an opamp to drive the gate,the fet is hard on until there is 3 amps in the coil then the fet holds it there till end of transmit.
    From memory the gate voltage is between 4 to 5 volts during regulation,the opamp goes rail to rail with switch on and switch off.
    Except for the fet getting hot the cct works very well.The transmit width is 300 u/sec and freq is 1khz,will be trying diff fets over time to see if i can get one that runs a bit cooler.
    Tryed many opamps to drive the gate,most cant handle it.
    Zed
    • #32
      Zed
      Very interesting.
      What does the charge current ramp look like?
      Tinkerer
      • #33
        Tinkerer it looks almost identical to this pic but this pic is from a different cct and also it was running on a 6 volt battery,the current cct usus 12v so the current climbs a bit faster,from memory this cct reachs 3 amps in 100 to 150 u/secs.
        Zed
        • #34
          Zed
          Thanks for posting.
          I understand that you use the long flat top for experimenting with ground effects?
          Tinkerer
          • #35
            Thanks for posting.
            Tinkerer
            In a nut shell yes,the prevous cct had its short comings which promted me to try another cct [the one posted]
            I haven`t taken the newer cct for a run yet still more to do,i wanna try a new ground cancling cct.
            Zed
