TGSL Tuning & troubleshooting
    Vladimir, your capacitive load of opamp U105 creates instability. In theory it is avoided by a resistor as shown.
    It should be so but, on the contrary, now is the device without peaks and a lot more stable. Is your opinion of theoretical or is it trying to practically?
    In fact, I lost a few centimeters in depth, but given the stability.
    • Simonbaker
      Thanks for the graphic analysis, a lot will help me in future work.
      • Originally posted by Vladimir View Post
        Simonbaker
        I think your mod is interesting. In some ways it would be good to move it all to a separate thread called "Vladimir Mods", because this thread is really for troubleshooting the standard TGSL with very minor mods. You can ask Qiaohzi to do it if you want.
        Your mods make another version that may be well suited for deep detection. It is an interest I have had for some time.
        I think maybe your 200K for R26, R25 is a little too high. Maybe 50K to 100K better, but real tests needed.
        The zener diode for D12 is another interesting factor that is worth discussing later.
        • According attached theory, your circuit is in stabile region because of very low frequency band.
            Nice document!
              , Theory never enough.
                If the theory is not enough, then test the DC sensitivity and measure S/N ratio by a battery as signal source and voltage divider. The circuitry after demodulator should operate stabile.
                • Perhaps at this point it is desirable to describe the reasons for the modification TGSL basic version.
                  1. (S1) In this position of coils in relation to the ground, the unit is very unstable with frequent peaks.
                  2. (S2) If the spire rising high above the ground. unit is also very noisy.
                  3. In the operating position in the movement of coils to the left and right, the unit occasionally have unforeseen and random peaks.
                  4. Bad sensitivity of basic units, less than 25cm for 1EUR coin.
                  This is my experience with the first version TGSL plate and coil DD27cm.
                  The first change I made in Tx, I got a variable gain entrance to the possibility of better sensitivity (in extreme cases up to 45cm in the air).
                  Resistors R25 and R26 I have replaced the recommendation of my friend, and got a little bit slower response unit, that I personally prefer.
                  R29, R31 values increased due to better gain filter, such an experience I had with certain models of devices that I previously made, and the diode D12, which in this part of the much better solution than 4148.
                  Finally with the increased sensitivity and increase the noise. I think that the appropriate filtering and some loss of sensitivity could be found a satisfactory compromise.
                  It remains me a lot more testing on the ground but the results are already very good.
                  Greeting
                  • hi
                    ...i've got a great problem
                    when i was connecting my circuit for some mesurements i unfortunetly connected it like:+to - and _ to +;(
                    now my board is screaming from speaker
                    it's my foult and some foult of weather..it's wery hot..can you help me..it was a good board and worked not so bad..i just don't know where to search for bugs..please help
                    best regards
                    • it seem that without simonbaker there is no life hier:P does anyone can help me or sugest something in my case?:P:P best regards to all
                      • Originally posted by lunamay View Post
                        My guess is to check 7660, 7808 a few diodes there...I''m not sure if you have a diode connecting before the input of 7808. There is a reason people put those 1n4001 in front of everything....
                          Hi Lunamay ,
                          Yes , I think everbody's taking advantage of -SB's break and there all having a week off or reparing their pcb's damaged by all the mods and tests , it's hard to keep up with all the test and hints .
                          (The schema I'm refering to is from TGSL rev.3 by -SB 08/18/2009)
                          For your pcb I would suggest first to remove IC U107 / LM358 ; this one should trigger the audio .
                          If your audiobeep is still there with U107 removed , then the audioproblem is somewhere around TR9/TR3/TR2 .
                          It is hard to predict what's more damaged with the powersupply wrongly connected ...
                          Do you have a scoop ?
                          If you have removed U107 and it stops , put U107 back in and remove U106 , work your way back like this in a logical manner
                          It is also a possibility that more ic's have been damaged ....
                          Otherwise you should remove all the ic's from your pcb , except the cd4024 with the TX coil connected !!! : this one is generating your negative voltage , and check if the positive - and negative voltages are there and on the correct places .
                          Then check the Tx and from there the Rx part by placing U101 , measure step by step everything with scoop while placing the ic's from the start to the end of schema .
                          Like I said it very hard to tell from a distance what's wrong with your pcb .
                          I hope these hints give a good start .
                          The attachment 'TGS compare' gives you a good idea what to expect on serveral testpoints.
                          Allthough it was made for the TGS ( not the TGSL , there are some 'minor' changes ) you should be able to 'translate' it back to the TGSL.
                          The TGS Compare 1.pdf was a compare between on original TGS by Molzar ( on the right side of the document ?) versus a homemade TGS by Max.
                          Dennis the Mennis
                          • hi i've changed all ic's without lf353..i noticed same signal in speaker and my 7808 is crashed also..what should be next to check??
                            • I ended up testing and adjustment and stuck a box of super glue.
                              I wish everyone luck in their work.
                                change the transistor in the audio level
