Originally posted by dfbowers
View Post
I just need to double check some of my observations from last week when I get home, on what test point it was I was monitoring when nulling my coils.. it may have been U103 pin 7 now that I think about it.. All DC levels get filtered out downstream. Probably the same as monitoring at C12.
As far as Rx zero crossing goes, I have not found that it matters but Qiaozhi's argument makes sense, particularly from a quality control perspective. I may just pay particular attention to that when making subsequent coils just to help eliminate variables between coils and allowing for a full range of adjustment.
However, we should remember that just because we "ground-balanced" the RX signal in the GB channel, it still may have a rip-roaring effect in the DISC channel. So I think the "ground effect" can still "make waves" by interfering with the DISC channel, even to the extent of masking targets in some cases.
I also am thinking more about whether there really are two ground phenomena we have to watch out for: a) Qiaozhi's ground effect, which amplitude modulates the RX signal, and b) "hot rocks" which create a signal with a distinct phase that can also be discriminated out in the GB channel. My ferrite targets might be in that last category.
I think it might be worth starting a new thread to kick around ground balance subjects.
I will let you know about balancing with and without the null signal zero crossing under the GB sync pulse center next week when I have my scope to set it up.
I have not gotten to Spice simulations yet, but that's something I want to play with soon. I was wondering.. how would your simulations behave NOT grounding the Rx coil at all? Based on all my field test, the ONLY coil I have made that is suitable to be used in wet grass is the last one - Shields only connect to ground on the PCB and nowhere else.. Both leads from the Rx coil float free. Performance is not noticeably different is actual use and the benefits of a noise free coil on wet ground seems to be the way to go..
How about a sudden voltage pulse on the RX coil (but which side? both?)? That could be simulated.
I could believe that if static charge hits both sides of the RX coil simultaneously, but one side is grounded, a fat differential hits the op amp. On the other hand, if you don't ground, could we blow out our chip with a huge common mode pulse? Depends on current? Maybe protection diodes would fix that? (hey, that's a thought -- is your ungrounded RX coil endangering your PCB?)
BTW.. I found enough change on the beach in a few hours to buy my next set of batteries. I even found a euro! Finding coins in loose sand has it challenges as coins are more than likely on edge.. No gold yet, but I have a few days to go..
Don
Don
I had miserable luck the one time I took my Compadre to the beach. Nothing turned up but bottle caps. However, they groom the beach with a dragger, maybe part of the problem. But I was surprised. I'll try another beach with your TGSL and I expect some serious treasure.
Coins on edge... brings up a thought... a need for coils that lay down a more horizontal field in the ground (figure-eight coils?). I'm sure already looked into, but maybe that's the way to hunt the beach - once with regular coil, then again with horizontal field coil. It never ends!... fortunately
SB
