I'm still not ready for it, anyway I was wondering about the best shieldind solution in the coil making process:
I have 10" Hays shell which is the one I'm planning to use for tgsl.
I was thinking of 2 solutions: one is the sistem explained by ivconic: alluminium kitchen foil, bare wire around it for the contact to the screen, and, once nulled, everything sinked in a epoxy cast. The advantage is that one can lock the windings in the right nulling position just putting hot glue spots directly on the shell.
The other solution is to glue a bare wire on the 2 shells with cyanoachrilate, spray the inside with spray graphite (I have DueCI N77) as Tesoro does, but then how to lock the coil onto the shell for the nulling? I suppose that the glue can't attach well on the graphite sprayed...
Isn't the first method worse in therms on sensibility? I've seen that for PIs the second is preferable...
I want to be sure because that's the only shell I have and don't want to waste it...
