I pulled the transistors and both are OK. I rechecked the resistors for tolerance and OK, diodes and caps are OK too.
I scoped the circuit and the transistors are being driven correctly...
I noticed that the current draw on the -5v line is doubled when U4 is in place so I am coming to the conclusion that the -5v generator is working correctly and there is something wrong in a circuit connected to U4.
I put an IC socket onto some veroboard and connected U4 via 14 wires to the main board U4 socket. Now I can isolate the various circuits asociated with U4 by removing the wires to see which one is the culprit.
The circuits are:
U4(a) which are pins 2, 4 and 5.
U4(b) which are pins 1, 6 and 7.
U4(c) which are pins 8, 9 and 14.
U4(d) which are pins 10, 11 and 13.
Power circuit which are pins 3 and 12.
The circuits are:
