Originally posted by porkluvr
View Post
Chatter-wise most of the job is done by R42 C26. C26 is by my opinion ~4 times too large, and if left as is it just produces odd delays in audio response at weak target responses.
R43 sets the output threshold level to ~1.4V to linearise audio (darlington) and it is best if left as is.
"Sens." potentiometer is actually setting a threshold at which comparators will trigger, and subjectively it does not do much, because the same targets will sound the same at various different settings of this pot. If you set it too high you'll miss lots of deep targets, but the shallow ones will sound the same.
What you can do is replacing R44 with a real potentiometer. For my IGSL I bought a real stereo pot (2 channels) because variable R44 provides a real audio level control. OK, my values will be somewhat different, and I did some other changes as well. Anyway, if you want to experiment, replace R44 with 100k lin pot, and replace C26 with 22nF. Leave everything else as is. Or you may use my other values and replace R44 with 10k lin pot, replace R42 with 10k, R43 with 47k and leave everything else as is (don't replace C26). In case R44 is turned down to 0ohm, LM358 turns into a comparator and produces pure binary response.
Here is a LTspice file of this circuit for your pleasure
