I will have to wait until start working on mine... I am jealous...
Eduardo, are you going to build a coil for this detector?
I would like more info about what you are planning for this detector.
I used TGSL coil and it works perfectly. This detector really like NOCH system that is very accurate. The dual tone is also very nice. The depth in the air is not much, are 35cm for € 1 coin. The beauty of this is that if the detector NOCH system is off, the detector continues to operate with 2-tone system. For now I will do more tests and then I will find a metal box to put the PCB. The coil is still in the air, I have not attached with resin. Later I'll post more about this detector. When I have time I'll make a video too.
Thanks, will be interesting if you can do some field tests to see what depths your getting in the ground and how reliable the two tones are at such depths.
Dave
I will try next week to make a video of this detector tests in air. So far I have not the detector coil mounted and also not with the above resin. Whenever I get time, I'll finish it and I'll try to take the field for good.
Take your time Eduardo.
Of course we want to see this detector finished tomorrow, but we can wait a few days.
It is reasonable to take your time and do good work than to make something fast that will end up with bad results.
Thank you for your real support of my work. The parcel is on a way to you, I will track it too and inform you as soon as it will touch the France land.
A tracking number is RN525045275LT.
I also really want to know the result of the experiment. Many thanks KT315, RelicHunter88, eduardo1979 and other participants of this interesting experiment. Thank you for your good work! I wish you good luck!
