King Cobra PCB
  • #46
    Faceplates and housings look good
    They are nice just like a king cobra and he has a few that are drilled and a few with blank faceplate box mounting hardware also for 20$each its a pretty good deal I got some for my KC project and my GMT 1650 project .
    • #47
      Some notes I made while trying to repair a 4" GMT coil. I had to compare phases and amplitudes to a working 8" coil. I finally got it right using my 2 channel scope in Lissagous pattern mode, X-Y. TX signal on one input and receive on the other and set my gains to get me a nice oval in the middle of the screen. Then all I had to do was null until i got the same shape oval on the 4" that I had on the 8" coil.
      King Cobra 8" coil.
      Pins 1-4 22.6 ohm, 6.04mH
      Pins 2-3 22.8 ohm, 6.06mH
      14.53KHz
      When properly nulled, pin6 of the receive amp(LM30 should be 300-350mV p-p and should lag TX by 44uS..
      • #48
        IC's were been renumbered
        • #49
          Hi;
          These are still the same patterns slow filters - virtually the same as the Tesoro, identical solutions of discrimination. At the moment we are thinking rather of digital processing of the ADC - think about such solutions. In the era of ARM devices are only historical. You need to think differently - otherwise this forum is not the ears in the direction of modernity.
          Taktyk
          • #50
            Originally posted by Taktyk View Post
            Hi;
            Taktyk
            hello Taktyk, if you are russian so you have to be in course of all DIGITAL projects that people make and made. I do not see your profile - who are you? what is your native? what country and city you are living in?can you give direct link on your digital project? is it FREE and ASM code will be fully free from charge for any one? I ask because 'digital' ones I see around are ONLY commercialized, nobody wishes to give you ASM code and even HEX. people constantly asked me in PM to give them ASM code on CLONE-PI, STALKER etc. for example. and i did answer only - I am not in this field.
            • #51
              this is part of Tesoro Royal Sabre schematic. any thoughts what do a trigger and a pot SURFACE BLANKING? can anybody give a clipping from its manual with a mention of the tuning?
              • #52
                Surface blanking - detector will not detect items until adjustable depth-usually 1 to 5-6 sm from the surface.
                • #53
                  Or in drawing:
                  • #54
                    ups. thanks! it is a limiter of ALL-METAL circuit reply, as far as I catch it.
                    • #55
                      It is about filtering (cut) out strongest signal (usually signals from targets near to surface) in comparison with a threshold setting level.
                      If you raise the coil, the surface blanking effect disappears. Unwanted side-effect: you ca lost signal of bigger deeper targets too.
                      Very nice option in coin shooting at some terrains.
                      • #56
                        thanks again. can anyone give a logo King Cobra in good quality at PCB more than this I did?
                        • #57
                          Cobra pcb
                          Hows the cobra pcb layout coming along.?
                          • #58
                            will be done as soon as possible. quickly. will not take long.
                            • #59
                              Great work from you KT315 again. Thanks.
                              • #60
