For KT315
U1 pin 8 : add 100P on Ground.
U12 pin 1 : add 470k to +V
R75 : to -V
R27 : 10k or 1k ?
PCB rectified (1-2):
- my PCB has not the 100 pF on GND, but a place is there, so I added it.
- OK.
- no link to -V. really N.C.
- R27 is 1k.
also still change U3.2 pin 6 100pF, U14.2 6-7 pin 220k.
Agree, most probably is the same coil as for Golden Sabre etc... I didn't draw pcb for it yet. Not sure if i will ever. Because; basically it is the very same "platform" as Golden Sabre. Except use of 7660 instead 4024 and those 2 transistors in negative supply. Is it better? Maybe it has better features with 7660? Maybe not. I am not sure. And of course; unlike Golden Sabre, Cobra has ppoint mode (static, nonmotion). Nice. If i ever decide to draw pcb for it i would probably exclude Notch part again...
Taking of pinpoint mode, could this be extracted to work on your TGSL ?
I'm making a king cobra clone very soon. I'm adding manual ground balance 10and turn like.on the gold mountain GMT 1650.is it possible to amplify faint target signals without blasting good targets? And possibly adding volume control.and could an led read out of ground balance be done such as -and + like +3.5 or -2.8
I was entering the letters and numbers from the chips on my original KC board and wasn't getting anything.I'm still new and learning almost done with my igsl and my tgsl I'm gathering parts for my KC project.got a few of the original KC housings and shafts from Keith Wills.thanks again.
Reason: Misspelled words
