'bomb detector'
    Modern explosive detector can sniff a part of TNT in 200,000,000 part of air. The technique involved used xtal. and a organic sample glued in it. Some reptilian cells is the sample. Scientific discovered that certain animal cells react in presence of TNT. When the reaction between the small quantity of TNT in air and the sample is produced, the mass of xtal. suffers microchanges and oscillator suffers umbalancing.
      Cool, but let's presume bomb is packed in several plastic layers and than hidden somewhere in the car...possibly covered with some usuall things.
      So there are no TNT particles in air at all..
      At crosses (usually controled by police) there are much people, cars, dust... heat...all other possible "particles" in air except TNT particles..
      What than? Booooom!
      Only possible way to locate DIY bomb is to search manually...even than is tough!
        What than? Booooom!
        EVER particles scape from packages... This was demonstrated with drugs sniffing dogs of a special breed. The drug was covered and put into a can inmersed in water too, but the dog sniff it, because ever some particles scape.
          Reptilian Cells are becomming more prevelent!A change is taking place, estaban! you know this .Most still do not?...watching.
            Yes, particle sniffers are possible. Dogs are a good example. But these devices are just ordinary dowsing rods.
            3 more bombs went off in Baghdad today.
              Most till relate to road side bombs tho! Carl? check carefully!
                2 relate to AV,armour vehicle,an roadside bomb.A well known an developed Tactic Taliban Group!on the cheap with dv.results.! Who funded an trained early days?? usa anti ussr etc. 1980s +.yes we all Know!All Old school Politicin...
                  Deployment of any anti/bomb is still very primitive an inefect.an slow.Talk to your local vets. on the requirements!they expect to save lives!an what they want.Dont sperculate? Please be an end to Wars/mines an the Tech assoc. with it!Abandoned warfare devestates generations ahead!
                    The real soulution
                    Terrorists are the basic problem. The western world needs to get serious about the threat instead of pecking at the problem and slowly shutting down our freedoms.
                    The governments need to issue a simple proclamation. "the next terrorist caught will be interroragated, country of origin and location in the country of orgin of the terrorist will be ascertain and that origin will bewiped off the face of the earth. AND pig fat will cover all the bombs that do the clean up."
                    End of problem!
                    Read of Black Jack Pershing solution to terrorist in Philippines in WW I and you will know why this would work. It would only have to be executed once to show we mean business.
                      if Iraq was superior in military equpment and did invasion of USA... who then would be 'the terrorists'? you had got some hi tech advantage (Area-51 - S4 Dream Land, Dulce etc bases, some with alien-ET's presence. good matter, eah? huge un-control Black Budget $$$ on any development) and it gives you a right to attack first. it gives also you a right to call who is terrorist who is not. now you fell yourself absoliutely strong and safety.
                      the attack (occupation?) on Iraq is one step of your strategic huge plan to round China in ring of your military bases. second is Afganistan. third is Iran. oops.. seems... I forgot Yugoslavia?
                        So...finally...is there any real working "bomb detector" on the market (except dogs, reptilles, pigs etc....etc... )?
                          Originally posted by Rov View Post
                          Hi Muntari,hows your project going?Feel sure any if any outcomes will come from OZ.from deep developers like you.as we know ML started this way,an contibute globaly in the biggest way!Cheers! Rov.
                          Hi Rov,
                          Slowly at present due to other business activities but some field testing has been completed.
                          cheers
                          Muntari
                            And seems this not new molecular detection can be a good option.
                                http://publications.drdo.gov.in/gsdl...48.dir/doc.pdf
