Jeohunter - Visual Ground Scanner
  • Ground balance problem
    Hello Now i have Jeohunter but i am facing ground balance. I see the video. I do the same thing what they say but no use my jeohunter is giving continuous sound. what can i do?
    • shoveld answer
      hello friend finder later when i test my batteries is everything is ok i will tried to make shoveld liked you bro even if there is time for me . ok i can try my best friends
      i thing i will make a shoveld high tech bro just kidding bro .ok i can try my best friends
      • shoveld problem
        hello my friend sorry bro at the my country i cannot use this shoveld because it to small bro i use bigger shoveld in my country the soil is to hard and not uncertain soil bro but i will try to make it .
        • picture of joehunters
          hello syed can i see the pitcure your new joehuntes can you show me.
          • Hello FUNFINDER WHERE ARE YOU
            • ground balance sound
              hello syed sorry for answer your joehunters i am very busy guys tresure hunting bro .about your joehunters detector i don't now what model you having but i will try to help. the ground balance you having countinuos sound i thing is a sound of ground balance . you must don't test your joehunters at the area near any energy electric source or where the soil have to many metal object .
              fist switched the joehunters to on starts with the ground ''Adujust'' press the ground button and adjust ground setting lift the detector search coil 40cm above ground and press reset button you can heard a two different sound when you lift and lower your detector .if you do not understand ask funfinder that all bro what that i can help
              your friends
              geo-i
              • I buy new jeohunter 3D, I test in three different places, all are my gardens. there is no metal items near and beneath. i follow the instruction manual and guided video. no use. the jeohunter giving continues sound.
                • hello friends
                  i think there have something wrong with your detector you can return it back bro
                  markro compny have certificate warranty abut 2 year .
                  • batteris not last longer
                    hello my friend fun finder where have you been bro .i had a problem again with the batteris when charge is full but is not last longer with the lipro balancer charger i use your described connection digram you give to me . all 8 cell ultrafire is new at fourm you says it possible to charge every single cell diretly and need wires for each cell and sepecial loading housing can you show me how it to build it .thank
                    please reply friend
                    your friends geo-i
                    • hello my friend fun finder can you send me the video about iron -door 160x100cm insize got dtected by 2-7 to2-8 meters at 90% sensitivity on iron on thanks
                      geo-i
                      • Hi syed ayub basha!
                        Congratulation for your new Jeohunter.
                        Believe me, this was the best choice you could made and
                        a very valuable investment into your treasure-hunting future.
                        I'm sorry you have some problems at the moment but I'm shure
                        those will be solved very fast. For the beginning you may get a
                        little bit expierence first but you will see, after one week or so
                        you can work very good with this detector.
                        First we have to solve the continueing sound.
                        I need more information but if it is not a production issue you can try the following method:
                        This is very fast:
                        Switch on the Jeohunter - wait for the ground balance screen - press accept button.
                        Now press the setup touchpad at the upper left, you will see the below screen.
                        press two times the plus button and then the accept to go into sensitivity menu.
                        now press accept and minus to get 60% sensitivity and accept to save the value.
                        go back to the main menu and press setup and you're at the main detection screen.
                        Now you can press the reset button if the sound still is here and it should be quiet until you move metal object close. If not set sensitivity even lower and try again.
                        Maybe the only problem was that you have not pressed the reset button while making ground balance. While ground balancing lift coil from 10-40cm above ground, press reset button and plus minus until the detector all the time is quiet and finally accept.
                        Because of the very high sensitivity and the unique "static detection range" of the Jeohunter it will detect everything outside the very small "quiet band" which you can newly adjust everytime you press the reset button.
                        The easiest way in the beginning is to search with only 60-70% of sensitivity.
                        Hope I could help you and your Jeohunter works fine. And as geo-i already told - you will have 2 years of full warranty. Did you bought the standard version with 1 coil or the full version with all 3 coils?
                        Good luck, syed ayub basha!
                        • Hi geo-i,
                          thank you for helping syed ayub basha, I've been offline for some days.
                          Uploaded the video with the iron door here:
                          http://www.multiupload.com/TEDJC0QC8W
                          This was really amazing and it works even better if you move the whole body together with the moving coil. The Jeohunter is so sensitive it even can recognise if a human body is near the coil!
                          Now the help for your accu-pack:
                          I saw at your picture the auto-charging was at 4000mA. This is too low. Try if possible to load the accu pack at 6000mA so you can get the cells completly full.
                          For loading every single cell or create wires I would need a picture of the loading cable the charger provides.
                          You would need the exact pinouts corresponding with the cells and there is another problem:
                          You would need 2 times the same contacts for balancing each of the both series of 4 cells.
                          Example:
                          This is your connection at the moment:
                          __-- -[- 3.7liion +]-[- 3.7liion +]-[- 3.7liion +]-[- 3.7liion +]-+__
                          ....-- -[- 3.7liion +]-[- 3.7liion +]-[- 3.7liion +]-[- 3.7liion +]-+
                          The plug has only one plus and one minus pole.
                          For balancing charging you would need :
                          PIN1 (GND)--PIN2 (+4,2V)--PIN3 (+8,4V)--PIN3(+12,6V)---PIN5(+16,8V)
                          PIN6 (GND)--PIN7 (+4,2V)--PIN8 (+8,4V)--PIN9(+12,6V)---PIN10(+16,8V)
                          Your accupack would need 10 wires from inbetween the cells.
                          This is 2 times 5 wires with a connector that fits with described voltage of the balancing-charger-wires and the connector.
                          You have to check with a multimeter which charing wires have how much voltage so you could create a fitting connector.
                          If your lithium cells are still removable you can charge them one by one between the 0Voltage (ground) and the 4,2v contact wire.
                          You can create a little box which is accu sized and 2 electric contacts inside where you can connect the needed correct 2 cables of your lithium ion balance charger.
                          First I would try to load your accu-pack (manual) at 6000mA.
                          If your cells had all the same charging state before you charged them for the first time this should make your batteries really full.
                          Otherwise you can try to charge every single cell and after this reasamble your accu-pack.
                          Or you can buy an already ready to use 14,8v lithiumion-pack.
                          Hope this helps.
                          Good luck geo-i, find cool treasures and have fun with the video!
                          • thanks fun finder
                            hello my friends thank you for your support and info.we do hope to get along in this fourm in the future i will continue to give you my picture for our reference
                            ok bro .
                            • Pleasew Guide Me
                              Mr. funfinder The dealer technical person coming to my place on Monday. to train me. OK I have another question, in our place some one dump the currency notes in polythene bags, and they put all bags in to the one big 100 litters PLASTIC drum. They dig one land and put the drum in to 6 feet. IN THAT THERE IS NO METAL, now his son wants to find the item. his dad is no more. land is around 1 acre. can we find the item with our jeohunter. please guide me.
                              • Hi geo-i,
                                thank you bro for the info and i wish you good luck for super powerful accu-pack. I know you will have full success with accu-pack - your first accu-pack was already amazing!
                                Check out my newest invention!
                                http://www.geotech1.com/forums/showthread.php?t=18623
                                Nice greeting to you, syed ayub basha!
                                Good luck for Monday with the technical person.
                                And even more good luck that you will find the 100l drum!
                                This is a fantastic treasure!
                                I haven't tested it yet, but I'm almost shure it is possible
                                that you can find it with the Jeohunter!!!
                                Because 100l of "artificial space" inbetween the soil is a huge amount
                                of different electromagnetical field-strengt-absorbation.
                                And the ground above the treasure will be different, too.
                                OK, I don't know how much is 1 acre in India? 50x50 Meters like often in Europe? This would be easy and fast to detect if you make markings on the ground etc. but you have to search still carefully because of the 6ft depth.
                                First you could bury a large plastic-bottle and make some tests, using the same kind of soil. You can do this today with the help of the technical person for getting faster experience for the cavity detection. You can go with him to site that has the same soil so he can input the best possible ground balancing value for you.
                                And you can make the bottle test there.
                                You may also try the whirlwind search method for scanning very
                                fast 1,5 to 2,5m broad stripes of the whole area.
                                And check the ground if you see any suspicious burying signs
                                like stones etc.
                                Good luck and keep us informed!
