ARADO 120 SCH& PCB
    Hello Andreas,
    Nice work, just a creasy idée…… can this circuit work as a 2 box ?
    Best regards.
    Ap
      Originally posted by ANDREAS View Post
      This is not essential. Depending on the diameter coils and knowledge freq-osc
      we have different induction for resonate osc-circuit .
      Here we want osc work 4,68KHZ
      Only we must be try for make out this freq.
      Yes, Andreas, but I mean for those who have some old factory coils and maybe wish to try it with Arado. They can nothing to rewind only to compare inductance if suit or not.
        No problem if you wish post different coils for differents frequencies too.
          Originally posted by ApBerg View Post
          Hello Andreas,
          Best regards.
          Ap
          Hi Ap
          2-box, create idea, but if work or not i don't know
          best regards
            If you use old coils, it's easy resonate Rx coil, but don't work fine osc. This MD work with antifashe signal 90 degree. All parts are calculation from freq 4-6KHZ. In this size you can make "null" work meter and discrimination , but don't work voice circuit.
            It's better make two new coils from this MD. This is only my opinion. You can try and i wish for best results.
            best regards
              Hi Esteban
              Do you work Arado with other coils and other osc-freq?
              You know i have not free time for modification. Your opinion please
              Best regards
              Andreas
                Thank you andreas for this new project.
                It would be nice to see those complete and tested projects all together here, with the essential information on how to build them, like the TGS, DP, surmaster, and now this one, there is probably some more.
                  Hi Esteban
                  Best regards
                  Andreas
                  This is because you're old as me (50).
                    O.K Now i wait first member now , build this. Only in practice i can publish, method calibration this MD.
                    A tip PCB don't put capacitors C17,C18. We need here for calibration
                    best regards
                      best regards
                      Yes, those are high values capacitors due low frequency, 4.68 Khz.
                      Best regards
                        Best regards
                        Thank you Esteban, we need here your help.
                        Finish for me , I wait first PCB and start again in practice
                        Best regards
                          Best regards
                          Do you remember the variant with electronic capacitor for to helping the tune?
                          Best regards.
                            Best regards.
                            Yes, but is not time for this. We wait the first PCB
                              According to Ivconic, there is a large variable capacitor connected accross the TX/RX coils. After some thought, this does not make sense to me. I do not have (or had) access to this UK machine, so I do not know how this works.
                              Other coils use a trimmer cap, or more commonly a fixed value capacitor connected in this way accross the coils. If it is something that needs very infrequent adjustment, it makes sense to use a trimmer cap on the circuit board rather than an expensive mounted tuning capacitor.
                              I searched parts sources, and the large varicap diodes have become rare and/or are too expensive (as much as the tuning capacitor!). So that doesn't seem practical either.
                              If there is a need for an occasional tuning, it would make sense to use a trimmer in parallel with a smaller (and cheaper) available varicap diode.
                              I hope Andreas keeps us informed on this!
                                Originally posted by technos View Post
                                According to Ivconic, there is a large variable capacitor connected accross the TX/RX coils....
                                Yes is true , but my Arado build two years ago, i don't put this variable capacitor.
                                You know is very difficult resonate same two coils Tx/Rx. For this application Arado use this variable capacitor.. etc
                                My method is simple for your all. After you build PCB , you must build a electronic-cap with range 50-300n. With this electronic-cap we can make a fine tune Rx coil.If you find this parts (example 101,5n) then replace with normal capacitor/capacitors and only difficult point is a "null" Tx/Rx. With this method we don't need variable capacitor between Tx/Rx
                                best regards
