Delta pulse LCD display
  • Delta pulse LCD display
    My first post i have just finished building the delta pulse LCD display from the Turkish site works great but its in turkish mostly and didn't like the >>>>
    bar graph display so i edited the text for English and changed the bar graph to solid blocks looks great.
    you tube video
    http://www.youtube.com/watch?v=EUIdAg1ztOk
    site: http://translate.googleusercontent.c...sB-LYSX3HER5tg
    couldn't work out how to attach a file so its here.
    http://www.filefactory.com/file/b0fd994/n/delta-lcd.rar
    some pics:
      I have uploaded the hex file to Geotech1 as the other link not working.
        Nice Job dom44
          Thanks for uploading files Dom44
          Jose
            LCD
            Thanks !
            Ger.
              Hello my friend, i read that you translated the hex file from turkish to english, how did you do it? can you help me? i would like to translate it to Greek!
                    translate
                    translating the code is not difficult just look at the pic code in your pic burning software, you will see the ascii code to one side, look for the relavent text and edit it how you like then burn it and try it out.
                    It took me a few tryes to get it right but worked.
                      hello can you tell me the name of the pic burning program you used? thanks!
                      EDIT: NVM i found it! T H A N K S! i will upload soon the greek version!
                        hello again i have one important question, does this lcd use a switch to turn discrimination on and off? where does the switch connect? how can i set it up corectly?
                          Hi
                          You can build new digital dalta pulse.
                          With new name PIM-2
                          http://www.lugatek.com/forum/index.php?topic=150.0
                          or
                          http://www.geotech1.com/forums/showthread.php?t=18206
                          Regards.
                            hello i have allready built the dp maybe next time i will build the pim. im just confused of the two leds in the lcd circuit, (not the lcd of the delta pulse2 but the lcd of this hex in this post) what are they for????
                              Hi elbombaci or uykosuz
                              I see you your delta pulse lcd and i simulated it in peroteus
                              but is not that lcd on delta pulse2 in your site
                              It haven't 3 bar for discriminating!
                              Can you share right hex with us ?
                              Or can you share your source code to change it ourself ?
                              best regards
