Waterproof Connectors
  • Waterproof Connectors
    Does anyone recognize the manufacturer of the waterproof connectors that are sold at the following link?
    http://www.sunraydetector.com/waterproof_5.htm
    Sure, that's a 12mm style connector (so-called "M12") made by Molex (Brad Harrison division). I'm looking at using these on a new version of the SMPI so we can have interchangeable loops. Available in 3,4,5, and 8 pin versions.
    Tesoro uses a 16mm "M16" connector on their water machines. They're too big for our case. There is also an 8mm M8 connector which is really small.
      Thanks Carl!
      I've been looking for some good quality waterproof connectors to use, and those look nice. The price is quite steep, though.
      I've purchased some Switchcraft and JAE connectors in the past. Even though they are IP68 rated, they didn't look up to the task of handling the rough surf that I sometimes detect in.
      It's interesting that you should mention the SMPI. Guess what (slightly modified) detector I'm planning to use them on first. ;-)
        looking for cheap, fast, waterproof connectors
        ck:http://cgi.ebay.com/Waterproof-Outdo...item1e5b9825f0
        at $5.99 they are good.
