Nokta you may be meant of... sh-t of #1 degree. there are many talented bunco-steerers around the world... you are right that go on the forum and ask suggestion. keep yourself far away from the frauds!
For searching gold you use Minelabs PI from 2100 to 4500 or Whites TDI
NOCTA ,OGM ... and such expensive kindergarten toys are unusable for gold prospecting.
It depends what type of gold is being searched for. If it's gold nuggets, then yes a PI is a good choice. If it is gold coins, then something else would be more appropriate.
Agree. But if target is deep and in heavy terrain, no matter in what form gold is, only mentioned PI's are usable.
Idea is to search for all king of gold mostly in hill , or mountain
all king of gold , please from experience and best satisfaction tell me
what is better to use minelab or white's
"for all kind of gold mostly in hill" the best and not to expensive solution is Whites TDI. Probably you need additional coil for it, so you can build your own or buy some other brand even used ML coil suit well to TDI.
thank you on help ,
what is more expensive and better if have better for searching in hills
/than suggested /what will be for step upper in quality and performance give couple examples
if someone have
any experience with White's V3i , please give comment
he seems looking the new advertising of Nokta sh!ttector. these guys hope on good deep WEB searching indexing of the forum and their bullsh!ttector will found over by a naive people.
