new pulse hibrid n
  • #61
    puls star 2 pcb disk small plates .
    • #62
      other side
      • #63
        Large tiles pulse star2 Thomas Breuer.
        • #64
          other side
          • #65
            other side
            Hi Orbit,
            When you take close-up photos, you should switch to "macro" mode on your camera, otherwise the images will be out of focus. If you do not have a macro mode, then try placing the boards on a scanner.
            • #66
              hI thanks Guru.This is a scanner it turned out bad ,but I will send other for that day to paint them with the camera .
              • #67
                Hi,Orbit,the video shows very good sensitivity and stable operation, Bravo!
                How does the ground effect, and how many milliampers current consumed this PI?Frequency =?
                G.L.!
                • #68
                  Hi Gjorge. Frequency 350hz Ground balance is excellent, but in sales.
                  • #69
                    Hi Orbit.In Serbian forum you said that your hybrid is similar with the Minelab GP3000. You said that the hybrid has a Dual Voltage Technology (DVT) and multi-pulse technology. Why have you changed the story here?
                    • #70
                      Maikl and Ivconic feropoint and Steve and it is the same man provocateur.
                      • #71
                        download cover from the face and Mani is not me nor your forum or dialogue with you and you shavatio mint that these are two different detectors if I could have spit on your forum will not be here.
                        • #72
                          and it is well understood that these were two projects ,hybrid n or there is no connection with the detector as I wanted presented in his forum hobidetektori and that is my new writing multipulse detector at 4.3khz online hobidetektori can Only people who have less knowledge of it .
                          • #73
                            and do not let had ten names be yourself Ivconic
                            • #74
                              Hi Orbit,
                              Because the tops of the caps are in focus, maybe the problem is not focus but instead not enough depth of field because not enough light and also slow shutter blur. Use very bright light (sun light) to take pics. Also, move back -- if your digital has good resolution, will still be OK.
                              -SB
                              • #75
                                Orbit do not be angry. My nickname on the Serbian forums is "dr.jare". I know you said the two projects. One is a classical PI. The second is a multi-pulse PI. These two projects calling "hybrid". Video that you set applies to the multi pulse PI and you put the next photo.
