golden mask from MDETECTORS.COM
    g.m.2
    -ok,i think everything takes a bad turns.
    -during times i work with more than 6-10 detectors (fisher 1266,1270/m.explorer 1 and 2/tesoro tejon(my preffered)garret 2500 and ace 250/fisher cz7 a pro/) and i can tell you GOLDEN MASK 2 ITS NOT A BAD DETECTOR,special for this money.my problem was with "MDETECTORS"who forget to send my shafts and coil screw.
    -i dont want to create stupid situation between you guys-i like to think this is a CONSTRUCTIVE forum
    -in picture is what have i done at home with super glue and pipes and shafts from othe detectors
      Originally posted by mdetectors.com View Post
      Hallo Dear Friends,
      We have just received an report for this case and want to inform you that we don't know about this inconvenience.
      We have many-many clients from all over the world every day and we haven't unsatisfied clients, that's why i guarantee that the lower shaft and middle shaft will be send immediately, as we receive the address of the client.
      In addition will be send a present - carry bag for metal detector as compensation.
      We have 3 step control method before sending of the detectors and that's very strange about this mistake.
      If really this happen that problem is in our staff and we are very sorry.
      Best regards to all!
      It seems that mdetectors.com are going to resolve the problem.
      But you might now also need a replacement top shaft.
        kopiranti dajte semu za ovaj detektor , turbina irf530 irf9530 555 pa pokoi drajver i po neki kondenzator.
          scarface, repairing nexus coronado... you see LOW quality here... its handle was been broken at a base...
          good luck
          The stem shown in your picture is not an original Nexus one. Someone must have replaced it at some time with some poor quality parts.
            Some photos from GM3
              Hi,Have you any other pictures with better quality?
                WhyYou want correct something??? I have another photos, yes, but on my Golden Mask there are two back to back sticked loudspeackers-very interesting engineering decision
                  Hi.
                  I have not something good. I did not use the macro option, so the quality is bad (bad focus).
                    g.m.2-problem resolved
                    -my problem with "mdetectors" is solved now-they send my tubes and a gift (a detector bag)
                    -i want to thank you guys becose u leave me to post here my problem.so good luck everybody.
                      Congratulation to MDetectors
                        All our clients are happy form service and products.
                        In this case was a problem with comunication by emails.
                        See new prices for November in
                        http://mdetectors.com/index.php?cPath=21_53
                        SEF search coils are included for some of the paks.
                        Best regards!
                          -anyway its just a pieces of ****.
                            Why do you think so? Do you test it in field?
                              -i have done alot of test in air and field test and was compared with:fisher 1270,micron sl 2006,tesoro tejon,xp goldmax,minelab explorer 2 and garrett 2500 gti.i can tell you G.M.2 was the worst machine between all of this-i talk abaut depth not nessesary discrimination.the only good thing was good signal at 1,8 cm coin under mineralization ceramic at 12-13 cm deep(fisher 1270,explorer and garrett 2500 have big problem with this,tesoro tejon have this problem but not so big).G.M.2 better discrimination than fisher 1270 and tejon at big iron object,but very big problem with small target--0.8cm coin at 10 cm depth in normal soil no signal at all/2 cm coin at 30-32cm in normal soil no signal at all.
                              and many more
                              -the differences between air test and soil test its very big with this detector i thing more then 30-35%.for example a silver ring 2 cm diameter and 8 grams -in air 35-38 cm in soil maxim 25-27 cm.a coca-cola can 70-75 in air BUT no more then 50 in normal soil and this with trash hold and sensivity very hight value which you cant search because u have all the time bad signal.
                              -i thing they made to alt of publicity of g.m. tests IN AIR NOT IN SOIL.
                                and many more
                                L.
                                No so bad results. Maybe your expectations are too high for this price range detector? I think that depth lost between soil and air test are normal.
                                2cm coin is hard to detect at 32cm in soil for most detectors. For some of its even in air.
                                What are your impressions about its stability in different conditions?
