golden mask from MDETECTORS.COM
  • #31
    -this "STABILITY in different condition" comes when you use trash hold pot (i dont think this is a truly trash hold-maybe a different sensivity) and sensivity pot BUT in some bad soil you need to degrease "trash hold" to much and u lose deep -1mm turn counter clock you may lose 2-5 cm deep at same target.for example i work with mine G.M.2 at 7 and i takes a 2 cm coin at 20-23 in normal soil degresing "trash hold"pot with just 1mm i lose 4-5cm deep at this target.i think vlado need to use a multiturn pot at "trash hold" because i think it give you a better range of tunning.
    -discrimination between iron and non-ferous is very good comparing with with other -in my tests only explore 2 was better and sometimes xp
    -you talk abaut "price range detector"-with this money you can buy better bulgarian detectors which unfortunately dont have to much publicity-maybe u know what i talk abaut(i dont give brands becose i dont make publicity or anti publicity)
    -this is my oppinion (maybe wrong,maybe good) but what i tell you its facts which its happens during 2 month testing this detector.i have my test field with different targets buried there and i can do tests any time BUT these tests wasnt made only here it was made in different soil and different conditions.
    -im not satisfied with this detector.
    -i love to chat with other G.M. owner and share opinion --i wnat to ask if somebody done some modification -special for depth
    • #32
      Thanks scarface, for your reported experience with GM2.
      I purchase another Bulgarian made MD (REX Delta 6) couple of days ago.
      Some air tests I done are excellent, but unfortunatelly, here is deep winter now, snow every day, and to the end of this year there is no hope to do some real field tests.
      But, as I say, air test are very good especially on small gold. Only I am not sure about its stability. We will se how it can manage real terrain.
      • #33
        -REX DELTA 6-its the first time i heard abaut it -i search on net lil bit and it look ok .you never know until u made some field tests.
        -i forget to sey abaut G.M.2 -recovery speed it is good comparing with many expensive detectors,special if the targets are the same size .if is a iron bigger then a non-ferous target it can be some problems.
        -can you give me some targets and distances of your air tests (example-1 euro coin.......25 cm) please.
        • #34
          I didnt try 1 euro (will do latter if you wish - now I am at job) but 30mm silver coin it sense at about 40cm and small gold nugget of 1.15gr at more than 7.5cm. I am interesting to use Delta 6 in first line as gold prospecting detector. I still have others good coin detectors so do not need to use it for coins.
          • #35
            -u have a nice job if u have time for this)
            -i think its very good deep 1,15 gr. its very small target and 40 cm for 30mm coin its more then ok.
            -u buy a very good detector.
            -good luck................in spring
            • #36
              Yes, nice job, but unregulary working time, it can be 12h per day too without overrun pay. IT. So I take some minutes here and there for relaksation instead of a lunch time.
              Sensitivity is ok, but I am not sure about its stabillty. There are some sign that it can be unstable. But we will se on field tests somewhere in beginning of next year.
              • #37
                Now I test 1euro coin too it is about 38-40cm in air, I cannot say exactly because only have 0-30cm plastic ruler at hand.
                • #38
                  re
                  -i forgot to tell you i use G.M.2 with 32 coil on this tests
                  -u know REX detectors its luxury division of MIKRON and mikron i like to thing its a BRAND in bulgarian detectors builders.they take alot of anti advertaising from other bulgarians brands but they sell very good because they build good machines.
                  • #39
                    I suppose so because there was adhesive tape on the package printed with Mikron address.
                    • #40
                      Yes, you are totally right, and again - as for Blisstool - all these anti advertising videos are made from Golden Mask producer.
                      • #41
                        -hy mister MLR i have a business for you: i give you my G.M.2 and you give me a BLISSTOLL!!!
                        -i undeastand you -i have good expectations for G.M.2 because i read what they sey abaut it,but..........
                        -i didnt test BLISSTOOL because i dont have one but i bet its better then G.M.
                        • #42
                          BIG MISTAKES,dear
                          If you want to buy Blisstool, you can do this here:
                          http://blisstool.com/
                          Maybe the owner will be glad to make change with you
                          • #43
                            Hello Geo and Everyone .
                            Happy 4th of July to Geotech Forum !!! To Geo : Did you or anyone else, ever field test the Golden Mask machine [that you took pictures of in October last year] ?
                            Are all the IC chip numbers sanded clean ?
                            Happy Holiday in U.S and Best Regards to Everyone on this Forum !!
                            HH...........Eugene
