Whites Prizm Pinpoint problem
  • Whites Prizm Pinpoint problem
    Hallo Dear Freinds,
    we have some problems with Whites Prizm /Coinhunter/ model.
    After some time pinpoint go down, but the metal detector works withowt any problem - only pinpoint take loud permanent sound.
    Are you familiar with this problem?
    Do you know how ti fix it?
    Thanks in advance!
    Originally posted by mdetectors.com View Post
    Hallo Dear Freinds,
    Thanks in advance!
    Remain this the same after repeating OFF/ON?
    Did you check if coil is clear: no metal or metallic ore like dirt stick on it?
    Did you replace coil screw with metallic one?
    Did you try to replace battery?
      I use diferent search coils on a clena area.
      Strat-stop, but the same plroblem, whan i press Pinpoint only permanent sound appear.
      Batteries which the buyer send were on 9,5V
        V
        In this case as next check if shield wire from PCB to connector (pin) inside box was somewhere poorly connected or disrupted.
          ok i will try and will inform
