CHANCE Pcb's Finally Here
  • #31
    Received the board . nice work! Thanks
    • #32
      CHANCE PCB'S - Problem
      CHANCE problems
      I have been working on mine this week and along with Jakub have noticed missing grounds etc...
      I fear I may have made a mistake on these, although I am still a bit confused
      The light blue layer in andy_f chance.pdf I thought was a solder mask and appears to be a top copper layer - hopefuly we can still use these boards with some jumpers as a test
      If a top layer ground is also required how is the one working shown below ? I guess not using Andy_F board layout ?
      If a copper top layer is used, I guess it is ok to use thru hole plating on every hole still ?
      My apologies for anyone with one of these boards - lets work together and sort these jumpers wires out so we can get a working unit
      I promise anyone who has purchased a board, once sorted and a new layout agreed, and if CHANCE works ok, I will get new boards made and
      you can have a free replacement - I would have to ask for the $4 postage though
      Silverdog
      • #33
        silverdog,
        I ask you again. give a chance to Chance literally. people has not these f-king American credit cards, you are thinking all folks has to have them as the rule. NOT. a credit card is chargest thing to open and pay for. for our part of world. ask you again - OPEN YOUR MIND AND YOUR CHRISTIAN SOUL FOR SIMPLE FOLKS OVERBOARD CONUS.
        in last hope you will take right conclusion.
        • #34
          kt315
          not sure what you are asking ?
          If you mean will I accept Western Union, then yes very soon I will
          A WU agent is opening near me within 2 weeks
          Silverdog
          • #35
            hi silverdog
            just missing the blue face, I'll try soldering bridges and try to see if it works.
            the moment is better than not do not do it has begun to wait for results.
            Sorry my English
            • #36
              with the bridges I do not work.
              may be that some component is damaged?
              now I have no time, if you get it to work, I'll put here
              • #37
                just started
                • #38
                  CHANCE problems
                  Silverdog
                  Silverdog, Any updates on when the new boards will be available? Thanks.
                  • #39
                    New CHANCE boards are here and working !!
                    I have added the boards to my shop, in the kit section I have also added the board with a preprogrammed Atmega, should you not have the ability to do your own. Full kits will be added in a few days.
                    A few more components have been added as well
                    www.silverdog.co.uk
                    Silverdog
                    • #40
                      CHANCE problems
                      Silverdog
                      what is that wrapped around that large cap ?
                      • #41
                        That is bare wire, it goes around the cap, thru a pcb hole on each side and is soldered undeneath, used above I believe to join 2 ground areas together. Not required on my 2 sided boards but there as they are in ANDY_F's original design
                        • #42
                          Good news
                          That is good to hear!! Don't want to have to set up to program the Atmega. Had enough of that with the z80s and 6502s Can't wait for the kit!!
                          • #43
                            Chance Order to SilverDog
                            I spent this morning an order for 1 x CHANCE + Atmega8 . Now I am waiting the arrival of this command to begin execution. Regards
                            • #44
                              Hi Silverdog,
                              Can you mention who/where you get your boards manufactured, good job and looks like the price might be right. I require some with silkscreen etc. for other projects.
                              Cheers
                              • #45
                                Order Delivery
                                Hi all,
                                I receive todaye from silverdog my Chance PCB. Quick delivery and very good quality.
                                Many thanks to
                                silverdog.
