CHANCE Pcb's Finally Here
  • #91
    Hi All, I just finished making the chance PI and it's running firmware ver 1.2.1 it seems to be functioning correctly. I did the mods replacing Q2 and changing R9 but I did leave out D9 which normally would be located in parallel with R25 470k. So D9 doesn't seem to serve any purpose.
    Other changes I did where the replacement of D4 and D6 they are now BYW96e because I didn't have access to the originals. Also I used BC639 and BC640 transistors in place of the ones listed.
    The coil I used for testing was one half of a DD coil which is about 8" diameter and about 27 turns of magnet wire then electrical tape over it and a layer of foil then another layer of electrical tape. The coil lead is about 6ft of 75 ohm TV cable because that's what I had on hand.
    Testing in my backyard I was able to detect an Australian 20c coin at between 30-35cm and a 1/2gram lead sinker at between 10-15cm. That was with the barrier set at 1.
    Next will be testing out of town away from interference.
    Mick
    • #92
      Did anyone do a field test with this detector yet? I have only read about air-tests on this forum. I have taken it to a field yesterday. Results seem a little disappointing.
      Fields I visit tend to have a lot of iron. The Chance detector goes nuts on these fields, I keep on digging the somewhat larger iron objects. With iron mask set at 3, the detector is a lot quieter, but it misses copper coins in this mode.
      Have been playing with the guard interval, does not seem to help.
      Also, depth is about 15 cm for a copper coin. Your average detector from the shop will do a lot better.
      Can anyone share their experience please?
      • #93
        golden words... maybe a time to begin new project there... I can ask Konstantin Saveljev to deliver PCB and chip for SPEKTR M1036 if you need about...
        http://md4all.ru/index.php?showforum=24
        • #94
          Need to purchase CHANCE PI, any person to sell can contact me [email protected]
          • #95
