Has anybody ever tried/thought to use a satellite LNB to amplify the signal in a detector? After all it is a low noise amplifier. Any thoughts?
Satellite LNB as an Amplifier
Originally posted by mikebg View PostScuba, do you know at what frequencies operate satellites and what frequencies are suitable for metal detectors?
LNAs & LNBs are typically bandpass amps, where the bandpass region is in the GHz range. They have a low noise figure specifically because they are bandpass. Make them low-pass, and they will be average. Better to use a good low noise opamp. You could do a little better with a discrete front end but usually not worth the trouble.
- Carl
I modded already 2 LNBs into UHF amplifiers.
The gain is around 20 dB and the frequ.-range ca. 900 MHz - 2.2 GHz.
The original usual consumers Sat signal is from 11.5 GHz - 13 GHz
but fot better coax-cable transmission it gets downconverted into the LNB to ca. 1.5 GHz.
As long as micro-waves can't penetrate the ground very well such
amps are almost usesless for metal-detection, but you can use it for amateur-radio stuff or better WiFi-reception.
Originally posted by Funfinder View PostI modded already 2 LNBs into UHF amplifiers.
The main problem of metal detectors is that sensitivity is not limited by thermal noise but by three much larger signals:
GND (ground),
AIR (induction disbalance) and
INT (interference).
They so limit usable gain (radio frequency amplification), that depth of detecting can not be improved by low noise amplification (LNA). Only automatic suppressing of mentioned three signals can improve sensitivity and then using LNA makes sense. See this thread:
http://www.geotech1.com/forums/showt...eferrerid=2910
