question on the White's TM-808 hoard hunter
  • question on the White's TM-808 hoard hunter
    hi guys
    i have bean looking at this machine and thinking of possibly buying one. my question is. what is the smallest size ferrous non ferrous sized objects will it pick up. also is this machine just an all metal mode machine only.
    does anyone on the site use one of these machines regular and has had good results with it. or are you just fed up with digging iron targets every 5 minutes. thanks in advance...
    Originally posted by keith777 View Post
    hi guys
    the tm 808 very good and perfect system. the new metal realy in the deep manual (factory) exampel.3inch=1meter 6 inch=1.30 and... but old metal and rilck in to the soil very deeping.exampele 3inch=1.50meter ok. how to the found gold please balance system.2 signal balance+ meter shown 50 thershhold- the hum sound very very low . point the gold thershhold off the sound hum off but metallic thershhold sound high
      thanks for the reply pourang but i find part of your reply a bit confusing ?
        1.balanceing the system please read the manuel(catalog) 2.volume signal balance a little round + . 3.after signal balance round the + .meter shown the 50 or 20 or 10 the found smal gold better than meter shown the 10 . 4.thershhold round the - until sound hummmm very low ok. the point the gold sound hummmmm very very low until off and meter down- exampele meter shown the 10 point in to the gold meter down up 10 (all tr metal detector up meter and sound for a metallic ..and.. meter and sound down for non metal(gold)
          hi again..
          i have just acquired a tm800 model. is there much difference between the two models apart from the cave mode.
            hi
            hi again..
            HI THE TM 800 OLD MODEL not made.but tm808 perfect than as tm800 becuse the tm808 in the board one criystal for a estabil ferqunce.the tm 808 estabil than as tm 800 but tm 808 no cave mode the tf900 cave mode the tm 800 desigen the discovery., just cave mode descovery tf900
              hi again..
              whites tm808 beter than as tm800
                TM 808
                hi guys
                Hello
                The TM 808 can find only objects biger than large coin,it will ignore all the iron nails and other small iron.But will find one horse shoe very deep,i found many,but also good things.
                Air distance in one aluminium can is 1.20 m.
                I have one for sale,not expensive.
                  hi morgan thanks for the reply...
                  when searching can you tell the difference when you have a ferrous or a non ferrous object in the ground. is their any tell tail signs like change in tone,pitch etc.
                    TM 808
                    This two box is not a discriminator,you not notice any diference in tone when detect iron or other metals.
                      TM 808
                      Have a look in youtube,a lot of people use the TM808 for finding WWII material (made of iron).
                        thanks morgan.
                        so i guess i am going to be digging an awful lot more than i normally would be with my minelab explorer. unless the field you are searching in has fewer targets in.
                          if you have any good links for a video that would be great.....
                            Hello, i look for the best two box detector - to search for large and deep objects. Because TF-900 seems not made anymore i decide to choose between TM 808 and GTI 2500 with eagle eye. Which one is better?.
                            Dest
                              hi
                              Dest
                              TM808 better than as tf900 and gti 2500. tf900 no meter tm808 meter.gti 2500 no good becuase sensetive the minral.but tm 808 perfect system and profitional.
